Old September 14th, 2009, 01:41 PM
billygoat is on a distinguished road
Default Quits in cycle, sometimes won't drain
I have an MDB9150AWB that's about 5yrs old. One day the cycle was dwelling. It was full of hot water and just sitting there. The circuit board was making a faint clicking sound like a relay was trying to hold, but couldn't. I investigated and found that one component was dangling from the PCB. I taped it back in place and it ran ok...for a week. Then it did the same thing again and I rechecked the tape job. This time a relay coil looked burnt. I ordered and replaced the PCB.
After doing this, the timer LCD no longer dimmed/shuddered, but it still stops after either the first fill or after the first wash and doesn't restart. When it stalls there is still a faint relay clicking, but I can't tell if it's a regular click or just when I end the cycle and dry to get it to drain.
As before, when I end the cycle by pressing the drain/off button, only sometimes does it actually drain. If I interrupt the cycle and try to drain it, again it's intermittent as to whether or not it will drain.
I can't imagine I have a bad new PCB. The symptoms are very similar. Any thoughts?
Old September 14th, 2009, 03:01 PM
Thats kinda strange, where did you get the PCB from? If may have come new, but possibly defective.
Manufacturer's Number: 99002825
Old September 14th, 2009, 05:05 PM
I bought it from appliancepartpros.com. It came wrapped in bubble wrap, but I can't remember if it was in an air tight bag.
Think I should return the PCB?
Old September 14th, 2009, 08:42 PM
Yes, you should.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/16566-quits-cycle-sometimes-wont-drain.html
Posted By For Type Date
Maytag/Magic Chef/Admiral/Jenn-Air on Appliance Blog Forums | BoardReader This thread Refback September 22nd, 2009 03:34 AM
[FIXED] Kenmore 665 not draining on final drain cycle pj@ Sears Kenmore 7 November 19th, 2008 08:24 PM
Quiet Partner skipping drain cycle Geof Whirlpool 3 December 7th, 2007 09:13 PM
Maytag MDB6600AWW Won't Drain cyboc Maytag/Magic Chef/Admiral/Jenn-Air 2 August 18th, 2007 12:07 AM
Maytag MDB5100AWW leaking, won't cycle or drain Chailena Maytag/Magic Chef/Admiral/Jenn-Air 8 April 21st, 2007 11:34 AM
Kitchenaid KUDS25SH Cancel / drain cycle dmccarthy KitchenAid 3 March 16th, 2006 06:04 PM
