Old September 22nd, 2009, 01:18 PM
bfrizzo is on a distinguished road
Default Maytag washer won't spin M#HAV2557AWW
Hi, I have a maytag washer that won't spin. The motor, belt, and thrust bearing are all in good shape. When I manually turn the transmission it agitates when spun in either direction. There never seems to be any downward force to lock the thrust bearing into spin. This is all the more familiar I am with maytag's. Any suggestions?
Brandon
Old September 22nd, 2009, 03:46 PM
Ok Brandon, Then the transmission is the problem.
How old is this washer? If you don't know post the serial# of your washer and I can tell you.
You should have a 5 yr. parts warranty on the transmission from Maytag.
Here's the transmission for your model:
Manufacturer part number 35-6615 is RepairClinic item number 1472816
35-6615
If you change the transmission yourself, its a big job, be prepared for an all day job.
bfrizzo (September 22nd, 2009)
Old September 22nd, 2009, 05:44 PM
Serial # 10383635cx. I believe it was purchased 01/1994. It is a friends grandparents. I was an appliance tech for 12 years but mainly for GE. Does this need a spanner to take out the spin basket?
Brandon
Old September 22nd, 2009, 08:19 PM
No Brandon,
The spin basket is just held in by 4 bolts once you remove the agitator you will see them.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/16622-maytag-washer-wont-spin-m-hav2557aww.html
Posted By For Type Date
Maytag/Magic Chef/Admiral/Jenn-Air on Appliance Blog Forums | BoardReader This thread Refback October 3rd, 2009 06:37 PM
Maytag Performa Washer won't spin properly theripster Maytag/Magic Chef/Admiral/Jenn-Air 0 June 8th, 2009 06:32 PM
Noisy In Spin Maytag Washer kjr232 Maytag/Magic Chef/Admiral/Jenn-Air 4 May 23rd, 2008 10:40 AM
Maytag Dependable Care Washer Squeal/Sqweak on Spin Start ggallant Maytag/Magic Chef/Admiral/Jenn-Air 7 April 9th, 2007 11:43 AM
Maytag PAV1000AWW washer won't spin unless helped erasmusk Washers 5 November 26th, 2006 08:37 PM
Maytag Performa Washer will not spin jskaldorf Maytag/Magic Chef/Admiral/Jenn-Air 5 August 1st, 2006 02:23 PM
