This dishwasher was working fine a not too long ago, now we are noticing that the dishes are not getting washed. It runs through all the cycles fine. It fills and drains the water fine. What I noticed was that when it does get to the wash cycle, the water pressure is not good enough to turn the washer arms, both top and bottom.
Does anyone have an idea where to start? Since the water drains, I figured it was not the pump, but not sure if the drain and wash used the same pump. Any help would be appreciated. Thanks, Dave Barkley |
Hi Dave,
Its likely the motor assembly: Manufacturer part number 6-904608 is RepairClinic item number 1472618 6-904608Jake
Hey thanks. I checked out the part and not too bad priced really.
Quick question. Do you by chance know does it come out through the inside or through the bottom. I guess I will find out once I start tearing into it, was just wondering. Once again thanks. Last edited by dbarkley; September 25th, 2009 at 10:20 AM.. Reason: needed to add more info |
It pushes up from the bottom into your tub.
Thanks. Will be my project next week. Until then I will be doing dishes by hand.
Ok, keep us posted.
Well it has been a little bit, kind of put this project by the wayside. Doing dishes by hand for now. Last night, removed the old part. It went better than I thought. I ordered the new piece today and should have it by the 10th.
Ok, sounds good.
| Replacing a washing machine | DaveServo | Sears Kenmore | 5 | August 15th, 2009 11:44 AM |
| Washing Machine Motor Serial | delroy | Washers | 2 | April 17th, 2009 01:24 AM |
| [FIXED] Washing Machine Motor Upgrade Wiring | billyjoe46 | GE/Hotpoint | 6 | October 16th, 2008 08:00 PM |
| Dinosaur Washing Machine Problem | stingraze | Sears Kenmore | 1 | February 6th, 2007 08:38 PM |
| kelvinator washing machine belt replacement | rbemrich | Washers | 5 | June 15th, 2006 12:24 AM |
