Old October 8th, 2009, 11:19 AM
rschwarz is on a distinguished road
Default Neptune MAH5500BWQ error code 5d?
Does anyone have a list of error/fault codes for a Maytag Neptune Washer model MAH5500BWQ? I am getting a code of 5d during the wash cycle but the washer still runs and finishes on time. The coe appears for a few seconds then disappears being replaced by the remaining time left.
Old October 8th, 2009, 02:54 PM
Here's the Maytag Neptune Repair Manual:
www.applianceblog.com/manuals/MaytagNeptunenew.pdf
I don't see that code listed though, you can double check for yourself to make sure.
Old October 8th, 2009, 03:21 PM
I saw that manual earlier and couldn't find it also. I thought maybe it could be a 'Sd' or '5d' code. I can't recreate the code so I will have to wait for it again and try to pinpoint what part of the cycle it is working on. I thought maybe the first wash phase.
Thanks anyways.
Old October 8th, 2009, 03:49 PM
Probably an Sd...
Display Codes in the electronic Maytag Neptune washers
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
The Following User Says Thank You to jeff1 For This Useful Post:
rschwarz (October 8th, 2009)
Old October 8th, 2009, 03:59 PM
Thanks, That now makes sense to the sporadic occurrence of this code.
Old October 8th, 2009, 07:03 PM
Senior Member
Robinh is on a distinguished road
Yes, my wife once had that code... was a mess afterwords...lol
Maytag Neptune Door Boot - do it yourself? taftsville1 Maytag/Magic Chef/Admiral/Jenn-Air 3 August 8th, 2009 06:08 PM
[FIXED] Washer MAH5500BWQ Bearing Issues rschwarz Maytag/Magic Chef/Admiral/Jenn-Air 3 July 28th, 2009 08:13 AM
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 09:40 AM
Do NOT pay for the Neptune Motor Conversion Kit 12002039 cyber16 Maytag/Magic Chef/Admiral/Jenn-Air 2 January 17th, 2008 09:40 PM
Neptune washer cold water won't fill Mark Thompson Maytag/Magic Chef/Admiral/Jenn-Air 3 June 11th, 2007 10:29 AM
