Old October 10th, 2009, 11:40 AM
Aabeddow is on a distinguished road
Default Myatag MSD2456DEW freezer iced up on the bottom, freezer and fridge not colling, still gets power
Myatag MSD2456DEW
The bottom of the freezer is a block of ice, it still gets power because the light comes on when you open the door, the freezer and the fridge are not cooling at all.
In the past we have had it freeze up on the bottom and simply had to defrost the condenser coils and make sure the drain tube is defrosted. Since then a copper wire has been routed from the heating element down into the defroster drain tube to keep it from freezing up.
Is it likely to be the same problem causing the freezer and fridge not to cool?
Old October 10th, 2009, 11:20 PM
Yes, possibly, do you hear the freezer fan running in the freezer?
Pull your refrigerator out from the wall, then take the lower access panel off and see if your compressor and condenser fan motor that sits next to the compressor are running.
Clear all the ice out from the bottom of your freezer.
[FIXED] Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold dieselgg Whirlpool 10 July 2nd, 2009 11:50 AM
Fridge not working - Freezer fine Kitchenaid KSRP25FNST00 jasa878 KitchenAid 1 June 19th, 2009 10:40 AM
Freezer cold / fridge warm (Sears Kenmore model 596.73913200 bottom freezer) John DeGrauw Sears Kenmore 1 September 2nd, 2008 11:28 AM
Kenmore Fridge with Bottom Freezer not Cold Rodney Davis Sears Kenmore 1 May 8th, 2008 06:33 PM
Kenmore fridge bottom freezing; freezer warm; no water bkmason Sears Kenmore 12 May 28th, 2007 11:00 AM
