Hi, I have checked the motor out and all is good in the 2-3 ohm params, my question is if I just replace the motor control board with a used/good one, will this happen again? What is the root cause of the fuse failure? Is it a board malfunction or motor overload? Can I just replace the fuse? Your advice would be appreciated. Everywhere I have looked suggests a quick, but expensive fix of getting the motor/board upgrade kit...your input please, thanks.
I wouldn't trust a used control board.
If your serial# starts with 17 or higher, then you will need this board: Machine control board kitIf your serial# starts with 16 or less you will need this board: Machine control board kitThe root cause is the door wax motor. You will need to replace that as well. Manufacturer part number 12002535 is RepairClinic item number 1063620 12002535Jake
My machine has never had the R11 issue, I replaced the wax motor long ago, it has the black plunger, not the brown, so R11 never blew, so timer control board is good. I'm talking about motor control board, went through these steps-
Netune tests page, motor test, Maytag neptune washer, how to take apart information, odor problems, my Neptune washer keeps shutting off, Maytag which brings me back to my original post.... BTW motor control board is located on the bottom right side of the machine facing the front, as if to use the machine. Fuse location on motor control board- F1, size 10A 250v |
Sorry about that, Yes, your motor control board. I don't know the root cause of the motor control board failure, but Maytag came out with the motor conversion kit years ago to solve this issue.
Here's the motor conversion kit for your model: Manufacturer's Number: 12002039 Now, like I mentioned before, I wouldn't myself trust a used board/motor, but thats up to you. Jake
| R11 ohm value for Maytag Neptune washer's Machine Control board | Samuel Huntington | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | June 20th, 2009 12:01 PM |
| [FIXED] Maytag MAH3000AWW, ocassionally won't drain/spin | docmag | Maytag/Magic Chef/Admiral/Jenn-Air | 23 | March 6th, 2009 09:44 AM |
| Maytag Neptune MAH3000AWW | laroc | Maytag/Magic Chef/Admiral/Jenn-Air | 9 | December 14th, 2008 08:47 AM |
| Maytag Neptune control board no | bobtb | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | August 31st, 2007 10:45 AM |
| Maytag Neptune Control Board Issue | tim205 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | January 17th, 2007 09:46 PM |
