Results 1 to 4 of 4
Thread: Maytag Gemini oven not heating up
    dm8282 is offline Premium Member
    Oct 2009
    Illinois
    Default Maytag Gemini oven not heating up
    My lower oven doesn't heat up. Can anyone help? What replacement part do I need? Model # MGR6775ADQ
    Ok,
    Open your oven door then turn on your oven and look at the very bottom and see if you notice an orange glow, you may need to hold the oven light switch in to see it, if its glowing orange and no flame is coming out, then your oven bake glow bar igniter is bad.
    Manufacturer's Number: 7432P143-60
    icon
    icon
    icon
    Oct 2009
    Illinois
    Thanks Jake for responding so quickly. I checked my oven, and there is no orange glow when I turn it on. What do I do next?
    Ok, you will need a multimeter to check for 120 volts at the oven igniter glow bar electrical connector when your oven is on.
    To access that, the connector is usually either under the oven itself, or in the back of your range, after you pull the range out from the wall and take the back panel off.
    If you get 120 volts at that connector with the oven ON, then the oven igniter glow bar is the culprit.
    Unplug your range first BEFORE taking the access panel off, then you can plug it back in when checking for 120 volts with the oven ON.
  1. Gas Maytag Gemini Oven problem
    By lonsplace in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 10th, 2008, 08:25 AM
  2. maytag oven problem
    By ck27362 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 2nd, 2008, 05:07 PM
  3. Heating coil for 1964 Frigidaire double oven
    By lpennock in forum Frigidaire/Tappan/Electrolux
    Last Post: January 9th, 2008, 09:13 PM
  4. Maytag double oven heating problems
    By Rox in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 25th, 2007, 12:01 PM
  5. MayTag Oven; displays OFF after oven cleaning?
    By Hansaplast in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 25th, 2007, 06:10 PM
