My Maytag MBB2256GES bottom freezer is not defrosting. How can I determine if the problem is a bad defrost timer or bad heater? Also, where are these parts located?
Here's the defrost timer for your model:
Manufacturer's Number: 67001036 Its #12 here: ![]() What I do is get a flathead screwdriver and turn it clockwise, there should be a small access hole under it to stick your screwdriver up in it to turn it, if your refrigerator is running when you turn it, turn it slowly till it shuts the refrigerator off, then it will be in defrost. Give it about 20-30 mintues to see if the defrost heater comes on and defrosts it, if so, then you have a bad defrost timer. Jake
Jake, the drawing does not correspond with my refrigerator. I removed the enclosure on the top of my freezer compartment. I contains only the thermostat assembly, light fixture, light switch and cable/connector. The cable/connector connects to a connector at the top of the freezer compartment.
Can you tell me where the defrost timer is located on this model? |
Unless you gave me the wrong model#, then that drawing is what I show as yours:
Wait, its in the refrigerator section, NOT freezer.
I put the freezer compartment back together then disassembled the assembly at the top/front/center of the top (refrigerator) compartment. After looking inside this assembly, I understood that you meant that the small hole access was from below, without the need to disassemble. I put it back together and then did as you suggested and turned the rotor inside the access hole clockwise. The refrigerator stopped running and it seemed that the heater came on. So probably a bad timer. I expected that the refrigerator would stay off (since I assume that if the timer is bad, it is not spinning), however after about 30 minutes, the refrigerator turned back on. I'm going to wait to see if it frosts up again. |
Yes, that can happen, but if the timer has a bad spot in it, it can hang somewhere in the regular cooling cycle, thus not going into the defrost cycle.
solarsurf (October 20th, 2009) | ||
Jake, I let it run for a few days. It seems to be defrosting again. That is, it seems like the timer may have been "stuck". Once I advanced it manually, it seems that it is functioning again. I'm going to keep an eye on it ... I'm sure I'll revisit this problem again. Thanks for your help!
Ok solarsurf, sounds good.
| Myatag MSD2456DEW freezer iced up on the bottom, freezer and fridge not colling, still gets power | Aabeddow | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | October 10th, 2009 11:20 PM |
| Freezer cold / fridge warm (Sears Kenmore model 596.73913200 bottom freezer) | John DeGrauw | Sears Kenmore | 1 | September 2nd, 2008 11:28 AM |
| GE Freezer -evap motor fan? | redlady4850 | GE/Hotpoint | 1 | November 11th, 2007 01:41 AM |
| Bottom Freezer (#596) Air Tower Repeatedly Freezing Up | amahler | Sears Kenmore | 17 | June 17th, 2006 07:25 PM |
| Bottom freezer model 596 | dms | Sears Kenmore | 16 | June 5th, 2006 12:34 AM |
