Old November 5th, 2009, 02:33 PM
timotb is on a distinguished road
Default [FIXED] Maytag dryer never shuts off automaticly
I have a Maytag model LDG8000AAW, Serial A3332825HF Natural gas dryer that will run forever cooking the cloths if not manually shut off. The dial never advances.
I have a lamp timer connected to the plug for 2 hour timed drying. Ive been doing this for years. About 2 years ago I bought from ebay a used replacement timer/dial mechanism. No change. I am guessing that unit was defective or it was not the problem.
I've vacuumed excess lint from the vent many times throughout the years with no change in performance....so I stopped.
Im going to try and address a fix once again. Any ideas?
Old November 5th, 2009, 05:03 PM
Ok, lets check the timer, put the timer on air fluff and see if it moves, if not then its the timer thats the problem.
Here's the timer for your model:
Manufacturer part number Y308221 is RepairClinic item number 1245992
Y308221
Old November 5th, 2009, 05:38 PM
I did a 10 minute air fluff and it advanced successfully with a buzzer at the end (haven't heard that in a while.)
Old November 5th, 2009, 07:12 PM
Ok, then the timer is good.
Now when you say you have it on a lamp timer to turn off in 2 hours, why 2 hours? Normal loads should dry in 1 hr or less.
I always pull the dryer away from the wall, then take the exhaust hose off and test a load with just the warm air blowing directly out the back of the dryer, and wait about 15-20 minutes to see if the timer starts to move. Try that and let me know.
Old November 5th, 2009, 07:16 PM
because this particular timer wont do less than 2 hours....and still some of the bigger loads takes longer.
let me try that second test
Old November 5th, 2009, 07:46 PM
See, what makes the timer move in auto-dry is when the heater is NOT on, so thats why it moved good in air fluff.
So if you have a vent restriction in the exhaust hose going to the outside of your house, that heater will cycle on and off so fast that the timer can't move.
Yes, try the second test and let me know.
Even with the heaviest of loads, it should still dry in 1 hr. or less.
Old November 5th, 2009, 07:48 PM
YES....the timer advances on regular dry cycle with vent unhooked punctuated with a buzzer again!
I suppose the issue is with the vent line?
Old November 5th, 2009, 09:15 PM
Yes, the issue is with the vent line.
Old November 6th, 2009, 03:53 AM
Thanks Jake....Im going out and completely replace the vent line with new material. Also looks like Im getting a new refrig. You are batting 1000 with me. Thanks again.
Old November 6th, 2009, 09:28 AM
Excellent timotb, good to hear.
[FIXED] Maytag Dryer MDG5500AWW wont get hot Jim Smyth Maytag/Magic Chef/Admiral/Jenn-Air 16 December 30th, 2008 11:44 AM
Maytag Electric Dryer GDE808 - Help!! jbird68 Maytag/Magic Chef/Admiral/Jenn-Air 9 August 18th, 2008 11:51 PM
Maytag Dryer won't turn Jim_art Maytag/Magic Chef/Admiral/Jenn-Air 4 January 26th, 2008 10:48 AM
MAYTAG MDE9316AYW dryer issues firebat Maytag/Magic Chef/Admiral/Jenn-Air 3 January 6th, 2008 11:41 AM
Maytag Legacy series dryer walks Jann K Maytag/Magic Chef/Admiral/Jenn-Air 6 December 3rd, 2007 08:41 PM
