Old November 15th, 2009, 09:00 AM
DaveServo is on a distinguished road
Default Maytag MDBD850AWW isn't rinsing
After a couple of loads of dishes coming out as dirty as when I put them in I discovered the bottom unit which spins and sprays water appears to be sticking. If I turn it manually, it spins freely about 1/3 of a turn or so then turns much harder but then frees up again. I wanted to take it out to see if something was stuck but I'm not sure how to do it. Any ideas?
Old November 15th, 2009, 10:14 AM
It sounds like your pump/motor assembly is starting to go out on you.
Here's the repair manual for your model, page 4-16 is the pump/motor section:
http://www.servicematters.com/maytag...s/16010622.pdf
You can also print out the pages you need.
Here's the pump/motor assembly for your model:
Manufacturer's Number: 6-917112
DaveServo (November 17th, 2009)
Old November 17th, 2009, 06:52 AM
Thanks! I opened it up and it turns out the micro filter was somehow warped. I suspect from the heating unit. Picking up a new one today.
Old November 17th, 2009, 10:25 AM
Excellect Dave, good job finding that.
Let me know what happens when you get the new one installed.
The #6 filter here?:
Manufacturer's Number: 99001791
icon
icon
icon
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 10:40 AM
[FIXED] Maytag MAH3000AWW, ocassionally won't drain/spin docmag Maytag/Magic Chef/Admiral/Jenn-Air 23 March 6th, 2009 10:44 AM
Maytag is No More in Newton Iowa Camster General Appliance Chat 6 April 28th, 2008 09:07 AM
Maytag 6100 is not rinsing - cloudy and grainy soap residue novice Maytag/Magic Chef/Admiral/Jenn-Air 1 December 25th, 2006 11:23 PM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 09:24 AM
