Old November 20th, 2009, 08:08 AM
bwpetzold is on a distinguished road
Default Maytag Oven Overheats
I ahave a Maytag electric double oven that overheats. When you turn on the top oven to any temperature, both elements come on and get extremely hot very quickly.
Old November 20th, 2009, 08:30 AM
Whats the model# of your Maytag? Its located either inside the oven door, or on the very bottom frame.
Old November 20th, 2009, 10:34 AM
Default Maytag Double Oven
It is a MEW5630DDW
Old November 20th, 2009, 04:19 PM
So if you turn your oven on to 350 degrees, both elements heat up? Do they turn off once it hits 350? Then does just the bake element cycle on after that?
Old November 20th, 2009, 05:13 PM
Default Maytag double oven overheating
Both elements come on untilit reaches 500 or so then turns off. It only does this on the top oven only. When it first happened "bake" showed up on the control panel but it doesnt anymore.
Old November 20th, 2009, 09:18 PM
Ok, its either the oven sensor or the control board.
To test the oven sensor, unplug the range or turn the breaker off to it, then ohm the sensor with an ohm meter, the normal reading will be 1100 ohms at room temperature.
Here's the oven sensor for your model:
Part#12001656
Manufacturer's Number: 74008993
icon
icon
icon
maytag oven problem ck27362 Maytag/Magic Chef/Admiral/Jenn-Air 3 April 2nd, 2008 04:07 PM
Slow gas on a Maytag MGR6775ADS Double oven... Y2KGTP Maytag/Magic Chef/Admiral/Jenn-Air 13 January 14th, 2008 10:56 AM
Maytag double oven heating problems Rox Maytag/Magic Chef/Admiral/Jenn-Air 5 October 25th, 2007 11:01 AM
MayTag Oven; displays OFF after oven cleaning? Hansaplast Maytag/Magic Chef/Admiral/Jenn-Air 3 February 25th, 2007 05:10 PM
Maytag Gas Oven - oven startup/popping problems kpd Maytag/Magic Chef/Admiral/Jenn-Air 1 April 11th, 2005 10:37 AM
