Results 1 to 10 of 10
Thread: Dishwasher leaking water at bottom of front door
    Oct 2005
    MD
    Question Dishwasher leaking water at bottom of front door
    Maytag Dishwasher -- model #WU7400AAX
    I inherited this dishwasher with the house, so I don't know how long it has had this problem. I can see the water running out of the bottom of the door. There's about 1 cup or more of water on the floor in front of the machine after each use. (Now that I think of it, there may be water going under the unit too. YUK!)
    Anyway, the black rubber thingy (I think it might be the gasket) is not identical on both sides, The termination on one side rounds through the bottom of the door opening, but on the other side it seems to have been ripped off. Come to think of it, I found a random piece of black rubber on the kitchen floor but didn't know where it came from. (Hmmm... could this be the work of my toddler? )
    Is the gasket difficult to replace? Can I pick up the parts at the Home Depot?
    Any insights/help would be appreciated.
    Thanks in advance
    Sounds like the door gasket is the problem, its easy to change, just pushes in, but the model# you posted is not showing thats a good number, please check it again, then we can give you a link to order the gasket.
    Oct 2005
    MD
    Default Oops
    I don't know how that big grin got in there...I guess I'm still getting used to a cyber lifestyle.
    Here's the corrected model #:DWU7400AAX
    That number worked great, thanks!
    Here is the link for the gasket you can order:
    Dishwasher door gasket
    Attached Thumbnails Attached Thumbnails Dishwasher leaking water at bottom of front door-maytagseal1296.jpg
    Oct 2005
    MD
    Unhappy Water still leaking...now what?
    OK. It's not the gasket. The water problem is even worse now. I was using kitchen towels at the base to catch the water at first, but now I've just stopped using the machine because the volume of water has only increased over time.
    My husband suggested that I needed to just try doing a normal maintenance cycle on the dishwasher and clean out whatever gunk may have collected, but I can't figure out what I would need to pull out and the Maytag website didn't offer a user manual (supposedly because the machine is so old).
    Does anyone know where I should start now?
    Is it time to call the repairman?
    I usually run the dishwasher 2-3 times/day. So, I really miss being able to use it. I"d love to just scrap this one and get a new one, but if this is a simple fix, I'd rather keep the money.
    Ok, a couple more things it could be is the spray arm cracked, the grommet broken around the dispenser door latch, or your door vent clogged or stuck shut.
    kenny w is offline Premium Member
    Sep 2011
    British Columbia
    There is one more option I just discovered with my Inglis. Take out the spray arm. The screws were loose below that. There are about 6- 8 screws
    angelworks is offline Member
    Oct 2011
    southern california
    how do i acces that spray arm?
    Whats the model# of yours?
    Click here to locate it.
    rwoodvet is offline Member
    Oct 2012
    Jacksonville FL
    I know its been a year since the last post, but I am now running into this problem. I have a Maytag DWU5902AAB that was also inherited through the purchase of the house. I took a look at the gasket, and was surprised that it didn't go completely seal around the door; the whole bottom edge has no gasket, nor a place for one. Anyway, I noticed that one side of the gasket was coming out, so I thought maybe that was the issue. I'm running my dishwasher now to see if that fixed it, but I'd also like to know from Lighthouse Wife, how her problem was resolved. What was the fix? Thank you
  1. Replies: 13
    Last Post: November 8th, 2012, 01:09 PM
  2. Replies: 4
    Last Post: May 28th, 2008, 08:53 PM
  3. Whirlpool Gold GU1200 leaking badly from front door
    By dougsteve in forum Whirlpool
    Last Post: July 9th, 2007, 01:02 PM
  4. Replies: 1
    Last Post: July 20th, 2006, 09:51 PM
  5. Kenmore front loading water leaking from door
    By sky_can in forum Sears Kenmore
    Last Post: October 20th, 2005, 05:10 PM
