Results 1 to 8 of 8
Thread: [FIXED] Maytag Dryer Won't turn off
    donc is offline Premium Member
    Sep 2008
    Harrisburg, NC
    Default [FIXED] Maytag Dryer Won't turn off
    Model Number: MDE4000AYW
    Brand: Maytag
    My Maytag Model MDE4000AYW, serial number 31435872YW won't turn off any longer. When the dial gets to the end of the cycle, it will continue to turn and the dryer remains on. We caught it once after the dial had made almost a full 360 degree turn. In addition, the dryer doesn't chime when it crosses the end cycle position.
    The dryer will stop running when the door is open but if you put your ear next to the dial you can hear it clicking and it is still moving.
    It does this same thing no matter what mode it is in. I tried it in timed-dry and it still continues past the 0 point.
    Any ideas what might be wrong?
    When they talk about a dryer timer is that part of the physical switch dial or is that a separate component?
    Can you get to all of that without taking the front door/panel off?
    Don
    Hi Don,
    Please double check your model#, I can't pull-up any information on that one.
    Yes, it sounds like a bad timer.
    If you close the dryer door does it start by-itself without you pushing the start button?
    Yes, the timer can be changed just from the top console, no need to remove any other panels.
    Sep 2008
    Harrisburg, NC
    Thanks for getting back to me.
    Hi Don,
    The model should be "MDE4000AYW" I originally read it off the back with a mirror.
    I had the wife do the test for you. When you open the door the dryer stops. When you close the door, you have to hit the start button for it to start again.
    Does it still sound like the timer?
    I took the cover off the dial and was hoping to find a screw. Instead it was just the end of a shaft. How do I remove the dial. Is there a diagram that shows how to remove the timer?
    Don
    Thanks Don,
    Yes, then its your timer thats bad.
    Here's the repair manual for your model, page 4-1 & 4-2 show how to change the timer:
    http://servicematters.com/maytag_lib...s/16023110.pdf
    Here's the timer for your model you can order:
    Manufacturer's Number: 33001730
    33001730
    Sep 2008
    Harrisburg, NC
    Thanks Jake,
    I just ordered the timer via your link and should have it by Wed.
    I will read the service manual tonight. It looks very helpful.
    Regards,
    Don
    Sounds good Don.
    Remember to unplug or turn the breaker off to your dryer first before opening it up.
    Keep us posted.
    Sep 2008
    Harrisburg, NC
    It's fixed!
    I got the timer today and replaced the existing one. I must admit, as appliance repairs go, this one was pretty simple.
    The only rub was one of the connectors got bent removing it and I had a little trouble getting it back onto the post of the new timer.
    Including cleaning the lint/dust out of the inside of the top panel the entire job took about 20 minutes.
    Thanks again for your help.
    Now that I am on a roll I am going to post about a problem that I am having with my Jenn-Air oven. Please check it out.
    Don
    Excellent Don, good job.
  1. 70-Series Dryer - won't turn
    By jimpenn in forum Sears Kenmore
    Last Post: December 16th, 2009, 04:28 PM
  2. [FIXED] Maytag Dryer MDG5500AWW wont get hot
    By Jim Smyth in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 30th, 2008, 10:44 AM
  3. Maytag Dryer won't turn
    By Jim_art in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 26th, 2008, 09:48 AM
  4. Maytag Legacy series dryer walks
    By Jann K in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 3rd, 2007, 07:41 PM
  5. maytag dryer heats but motor doesn't turn
    By fred9 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 29th, 2005, 04:22 PM
