Old February 8th, 2010, 05:15 PM
bdernbach is on a distinguished road
Default Islandhandyman
Model Number: MAH9700 Washr
Brand: Maytag
Age: 1 -5 years
I have had numerous issues with this, but this one is causing the most headache. My frontload washer soap dispenser drawer overflows with water. I have taken the top off and think that I have come to the conclusion that the "main" fill valve is bad. I just don't know if this could be a main board problem or the actual valve issue? What is the easiest and most likely place to test first? I have a multimeter and have read that the pin should read 1100 ohms, but these pins are on the main board side, what about the actual valves themselves that are running on the 110vac? Please help.
Old February 8th, 2010, 10:39 PM
Unfortunately, I haven't worked on these MAH9700 models to tell you what to check for.
But I did locate the repair manual for this model, hope this helps:
http://servicematters.com/maytag_lib...s/16025909.pdf
