June 11th, 2010, 06:39 PM
Maytag Oven and Broiler Won't Light....ignitor checks out OK
I have a Maytag CRG9700CAE Range. The range top works fine, but the oven and the broiler were working sporadically and now almost never light. I have checked the hot surface ignitor for the oven and it is fine, even the parts store clerk checked it and said I didn't need to replace it. Any ideas or suggestions are greatly appreciated?
June 11th, 2010, 11:29 PM
Sounds like the gas valve may be bad.
Your have a warranty on it from Maytag, since you say its under 1 year old.
June 13th, 2010, 02:27 PM
My mistake
The Range is out of warranty, a 1996 model.
June 13th, 2010, 03:22 PM
Ok, thanks.
Now when you turn the oven or broil on now does the igniters get orange in color and glow?
If not, then its more likely the clock/oven control board thats bad.
Manufacturer's Number: 12001613
June 15th, 2010, 01:19 PM
Checked you recommendations
The oven ignitor does glow, but gas didn't flow. I checked ignitor and it was fine, replaced the gas valve and that allowed gas to flow, but it never ignited, it did ignite if I used a match and fill the house with a gas smell when I didn't. The range is a 1996 model and I'm not sure if the life cycle justifies continued repairs, but I would like to know what the problem is. Also I replaced the control board 3 years ago when it went bad.
June 15th, 2010, 04:10 PM
How did you check your igniter? Did you ohm it when an ohm meter?
June 16th, 2010, 07:06 AM
Checked the ignitor and had the guy at the appliance repair shop check it when i went in to buy a new one. It tested fine, and the rep at the counter could have sold me a new one, so I believe it when he says it tested out, 3 amps if memory is correct.
June 16th, 2010, 11:42 AM
Ok, thats about right.
Yes, I'm stumped on this one, not sure whats going on.
By lonsplace in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 10th, 2008, 08:25 AM
By ck27362 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 2nd, 2008, 05:07 PM
By bandit1trucking in forum Sears Kenmore
Last Post: November 20th, 2006, 12:36 AM
By jimmer56 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 11th, 2006, 06:30 AM
