Old November 14th, 2005, 05:24 PM
mikfed is on a distinguished road
Question oven not working
I have a maytag model no. mer5750Baw, everything works on my control panel clock, timer, etc. stove top works fine, but I am unable to use my oven, broiler, or the clean function. When I put it on clean it will start up for a few seconds and than f9 comes up. The oven and broiler I am not able to use at all when pressed the lock lite flashes...any ideas out there
Old November 14th, 2005, 08:43 PM
Range in the fridge section....
F9....
F9 - Door/latch supervisory - Check door lock circuit or replace clock assembly (also called the ERC)
No power from the control is possible. Need to break out the volt/ohm meter and the ranges wire diagram.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old November 15th, 2005, 09:50 PM
Now I put the oven on bake and it had the lock lite on, I took a volt meter to the switch on the lock, and there was no power at the switch, than I took the wires off, I had a connection with the ohm meter one way, and with the handle in the other position I didn't.
So in simple terms when the lock was in the lock position I had a reading of zero, and when it was unlocked I had no reading.
According to the wire diagram...
...that sounds right for the switch.
Ohms the wires to and from the switch as well.
Looks like L1 at the clock and red of the elements....240 volts there and the oven is set but no 240 volts yellow to red or blue to red out of the clock = bad clock/control assembly.
Clock w/overlay (wht)
JRAppliance
Oven not working Granville GE/Hotpoint 5 March 14th, 2007 11:48 PM
Whirlpool GLP84800 Oven light not working ysp Whirlpool 2 January 31st, 2007 06:39 AM
Whirlpool range oven light not working ysp Whirlpool 1 January 30th, 2007 11:15 AM
Jenn-Air Convection oven not working Lmgustin Maytag/Magic Chef/Admiral/Jenn-Air 0 April 23rd, 2006 12:15 PM
GE JKP56 upper oven not working sceptic GE/Hotpoint 1 October 30th, 2005 10:29 AM
