Old November 15th, 2005, 05:28 PM
Alltan is on a distinguished road
Unhappy Fridge (MSD2356AEW) not cool enough
I have a 5+ year old Maytag side-by-side. The freezer part seems to be working okay but the fridge is not cooling its contents enough. I have defrosted the whole unit once already about 3 mths ago and it appeared to work for awhile after that. Now, the fridge is not cooling enough again. I also noticed that there is condensation in the lower part of the fridge where the vent from the freezer is. What is wrong with my refrigerator?Any help is appreciated.
Old November 15th, 2005, 06:47 PM
That would have to be investigated.
Some ocmmon things to check for....
Maytag Fridge model# MSD245GEW
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old November 16th, 2005, 12:46 PM
Unhappy Fridge not cooling now...
Checked around and inside the frzr/frdg and this is what we've found. The damper between the frzr/frdg was frozen over. Opened up the inside of the frzr back and found that the whole back side under the fan is cover with ice. Looks like the defroster is not working. Looking for the defroster time/thermostat now. Any ideas where the defroster timer/thermostat/itself is located for this model of Maytag (MSD2356AEW)?
Old November 17th, 2005, 05:39 AM
G'day,
Ice like an ice cube or frost like snow.
Ice might be a defrost cycle working but the water cannot get away, air leak, ice maker/water leak. Frost is more the defrost cycle is not working/comming on.
No defrost timer on this model, it has an electronic adaptive defrost board. Which is beside the controls in the FF section.
Defrost thermostat is attached to the cooling coils, the defrost heater is attached to the cooling coils block in the FZ section.
Adaptive defrost control board
Defrost heater and defrost thermostat assy
http://www.applianceaid.com/adaptive_defrost.html
JRAppliance
Old November 17th, 2005, 01:33 PM
Unhappy
It was frost like snow around where the damper was. When I opened up the back of the FZ, the frost covered up most of the coils.
Old November 17th, 2005, 08:07 PM
Unhappy Bad board?
Tested the adaptive defrost control board from the instructions in the link you sent. The fridge did not shut off. Instead there was a fast buzzing noise coming from the adaptive defrost board. When we touched the test to L1 again, the buzzing noise seem to slow down. Does that mean that the ADCB needs to be replaced?
Old November 18th, 2005, 05:59 AM
The fridge did not shut off. Instead there was a fast buzzing noise coming from the adaptive defrost board - Does that mean that the ADCB needs to be replaced?
Yupper!
JRAppliance
Kenmore Bottom-Freezer Fridge Icing up in Drainpan Hondatudinal Sears Kenmore 3 September 18th, 2007 08:46 PM
Kenmore Coldspot 106.63182302 Fridge not cool qweasdzxc63 Sears Kenmore 6 August 27th, 2006 09:48 AM
Fridge and Freezer cool but not cold - frost only on two coils in freezer. OpenUX Sears Kenmore 7 July 9th, 2006 01:38 AM
msd2556aew SS fridge does not cool gkg Maytag/Magic Chef/Admiral/Jenn-Air 19 October 31st, 2005 06:12 AM
