Old November 16th, 2005, 02:34 PM
chrisusvi is on a distinguished road
Unhappy new freezer bulb not working
I have a Maytag Plus 23.5 cu. ft. bottom freezer refrigerator. The bulb in the freezer blew the other day, so I got a new one and put it in and the new bulb doesn't work either. Any ideas or suggestions on what might be the problem?
Old November 16th, 2005, 02:55 PM
Sometimes when a appliance bulb feels like its tight in the socket, it really isn't. Try to turn it abit more, but don't force it if it doesn't want to turn.
You can also try just putting a regular 60 watt light bulb in to see if that works.
If it does, then the light bulb you bought for it is defective.
Old November 17th, 2005, 04:20 AM
Default new freezer bulb not working
After further investigation, I found that the bulb that was originally in the frig. was O.K. and the new bulb I got works also.
Could it be lever or switch that turns it on could be bad? I pressed in it and it felt like it didn't have much pressure against it. Is it supposed to have any type of pressure or is it supposed to be loose.
Old November 17th, 2005, 05:42 AM
G'day,
The light switch -may- be bad....how to check a common light switch.
I'm with Jake....sometimes the bulb just doesn't "home" all the way in the socket or the small solder tab on the bulb end isn't big enough to seat in the light socket correctly.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
2 yr. old freezer quit working! ltlgto Sears Kenmore 5 June 10th, 2007 12:22 PM
GE Chest Freezer not working waldreps GE/Hotpoint 17 February 28th, 2007 02:47 AM
New Kenmore frg/freezer - freezer not working sziff1 Sears Kenmore 2 January 22nd, 2007 09:26 AM
maytag s/s freezer not working fridge is fine reiavt Maytag/Magic Chef/Admiral/Jenn-Air 1 September 14th, 2006 01:15 AM
1998 Amana Side by Side Refrigerator - freezer not working tteller Amana 3 August 24th, 2005 11:31 PM
