July 21st, 2010, 08:08 PM
F1-8 Jenn air..Touch pad??
Bought this house 1.5 yr ago so i know the warranty is out. I also dont know the actual date of this range (I'm sure the Ser# tells me that)? I searched and it seems that the touchpad is bad with fault code F1-8, yes the burners work but not the oven. Are we sure it the touchpad?? I've done no trouble shooting yet. I'm a service tech (on pool motors and automated chemical controls which also have PCB's needing replacing) so i very comfortable with this type work. Do you have a tech manual for my unit, etc? THANKS!
Jenn air Model JES9800AAB, Ser# 23968410GE
thanks again!
Randy
July 22nd, 2010, 12:06 PM
Hi Randy,
Yes, this indicates a bad control panel.
Here's the tech. data sheet:
http://servicematters.com/maytag_lib...s/16025924.pdf
Here's the control panel for this model you can order:
Manufacturer's Number: 74005747
74005747
July 22nd, 2010, 09:44 PM
Thanks so much Jake, I'll perform a bit of trouble shooting....Checking Ribbon Cable connections etc. Looks like i'll be ordering a new touch pad. Thanks again.
I'll post up my results ASAP.
July 23rd, 2010, 11:48 AM
Ok Randy, sounds good.
August 21st, 2010, 06:28 AM
Well, the part finally arrived...been on backorder. I replaced it..no issues when doing so.
Problem: I now have F1-E code. control not calibrated. What can i do?? There has to be some type troubleshooting to do on this...not just be a "parts swapper"?
Please explain...thanks as always
August 21st, 2010, 01:53 PM
F1-E Control not calibrated. Replace control.
So it sounds like you had 2 problems, now you will need to order the control board.
Here's the control board for your model you can order here:
Manufacturer's Number: 74009320
True, but I did post the tech. data sheet above for all the troubleshooting and error codes.
Thats exactly what I use on appliances that I go out on.
So your choices are to replace the control board, or return the control panel for a FULL refund and buy a new range.
By PatrickM in forum Refrigerators & Freezers
Last Post: November 29th, 2011, 02:13 PM
By auburncasey in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 2nd, 2009, 09:59 AM
By pistofconsumr in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 6th, 2008, 04:31 PM
By cookswithgas in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 6th, 2007, 08:44 AM
