Old November 20th, 2005, 06:35 PM
Baker is on a distinguished road
Exclamation Maytag Washing Machine
Hi.
We have a Maytag Neptune Washer.
Model num: MAH3000AWW
We purchased it in 1999.
The washer has had repeated problems, but this is the worst: it stopped spinning. So we have just about given up on it as the repairs equal more than the value.
Do you have a suggestion?
Baker
Old November 20th, 2005, 11:56 PM
Do you know which parts have been replaced on this since you have had it?
The early Maytag Neptune's had many problems: (main control board, motor control board, door switch, drive motor, mildew oder problem).
If something other than the belt broke, its not worth putting anymore money into it.
Old November 21st, 2005, 09:44 AM
mikemac is on a distinguished road
I am not an expert here like Jake, but I had the same reaction you have 'time to buy a new one' at first, but I am glad I inspected it first, and found that it was only a belt and pulley that needs to be replaced.
If you hear the motor whirling sound but no spining, I bet the belt is gone too. At least thats what happened to mine.
Old November 21st, 2005, 04:58 PM
Arrow Hmm... maytag washer
All the parts you listed were replaced, I'm pretty sure.
There is somthing called the wax motor wax somthing,well whenever we replaced it would work for a while, then quit.
We will look at the belt.
Baker
Old November 21st, 2005, 05:00 PM
JG708 is on a distinguished road
Default Maytag Neptune Washer problems
Hifficeffice" />>>
We just purchased a Maytag Neptune Washer MAH9500.>>
This washer when in rinse and or spin shakes and walks all over our utility room. I leveled it moved it and tried just about everything to stop the violent shaking and waking this unit does. Is there any help you can give us to help remedy this situation and steady this washer. At the rate this unit shakes it won’t last a year, has damaged some walls, etc.
Jim>>
Old November 21st, 2005, 10:39 PM
Baker
Glad to help Baker!
The wax motor is what controls the door latch. I have replaced many of those.
Old November 21st, 2005, 10:41 PM
Originally Posted by JG708
Hifficeffice" />>>
Jim>>
Sounds like either the shocks are bad or the rear bearing is shot.
Jeff1 has a good webpage on the Neptune:
http://www.applianceaid.com/neptune.html
Old November 22nd, 2005, 09:30 PM
Brand new machine....was all the transit packaging removed by whoever installed it? There should be some info on how to do this in the paperwork you got with the machine.
Old November 23rd, 2005, 11:48 AM
Mad Macfficeffice" />>>
Thanks for the response. I believe you were responding to our Maytag 9500 Spin and Shake problem.>>
I checked and all packaging material, per the info from Maytag, was removed. This washer is almost unusable in its present state. I called for repairs from Maytag. It's incredible that Maytag or any other manufacture of front loader washes didn't come up with a simple counter-balance system for these washers. >>
Jim
Old November 23rd, 2005, 01:03 PM
Please let us know the outcome - there's clearly something odd going on. These normally don't present a problem when brand new unless the shipping material is left in or they're used on a weak floor (mobile home, upstairs laundry room), but never as violent as you describe.
Dinosaur Washing Machine Problem stingraze Sears Kenmore 1 February 6th, 2007 10:38 PM
Maytag Washing Machine wont spin or rinse!!! mymaytagdied Maytag/Magic Chef/Admiral/Jenn-Air 5 December 12th, 2006 12:11 PM
Installing a washing machine drain: Questions ron in sc Washers 1 September 20th, 2006 09:34 PM
Don't buy a 417.xxxxxx front-load washing machine (Kenmore but built by Frigidaire) ccadwellx Sears Kenmore Brand Forum 1 February 7th, 2006 07:22 PM
Maytag Neptune Washing Machine Leaking kpd Maytag/Magic Chef/Admiral/Jenn-Air 3 April 12th, 2005 03:49 PM
