Old November 30th, 2005, 07:59 AM
kwg kwg is offline
kwg is on a distinguished road
Default Jenn-Air JRSDE248T-Won't dispense ice
Ice maker produces ice and fills the chute but the chute trap door doesn't open. Please help. thanks.
Old November 30th, 2005, 12:57 PM
You will need to ohm the solenoid for continuity, check the solenoid plunger to make sure its moving properly. If one of these solenoid problem fail, then you will need a solenoid assembly.
Dispenser door solenoid
If the solenoid checks ok, Its likely the control board is bad.
Here is the control board for your model:
Control board, dispenser
Here is a link that may help you as well:
http://www.applianceaid.com/maytag-dispsnsers.html
Old January 25th, 2006, 06:04 AM
kwg kwg is offline
Default Icemaker fixed
Thanks Jake,
In the end the problem was the ice door strike. The solenoid has a short metal arm that fits into a molded groove on the strike. The edge on one side of the groove had broken off. when the solenoid activated the metal arm slipped because it wasn't kept completely in the molded slot and consequently wouldn't open the door fully. Works great now.
Old January 25th, 2006, 12:12 PM
Glad you got it fixed kwg!
Thanks for coming back to update us.
Kenmore Coldspot 106.56706500 won't dispense ice zappet Sears Kenmore 5 June 8th, 2007 01:18 AM
Kenmore Elite freezer door left open, ice maker won't dispense tcreasman Sears Kenmore 1 May 6th, 2007 11:21 AM
GE Icemaker: Makes Ice, Doesn't Dispense In Door? BradP GE/Hotpoint 12 October 23rd, 2006 12:51 AM
Jenn Air Downdraft Cooktop Replacement mfrank2109 Antique and Retro Appliance Chat 1 October 5th, 2006 11:39 PM
jenn air fridge blowing warm air ribeye35 Maytag/Magic Chef/Admiral/Jenn-Air 6 December 1st, 2004 02:23 PM
