November 20th, 2010, 08:41 AM
Jenn Air Oven SVE47500B oven light and fan stay on continuously.
I have a 14 year old Jenn Air SVE slide-in oven/range that recently malfunctioned. The clock display was too dim to view, but, all other aspects of the cooktop and oven were functional. I called in a service tech to fix the clock and when he disassembled the keypad/switch membrane the communications ribbon malfunctioned (probably due to brittleness, as it was doubled over inside the cramped space, and looked slightly discolored like a creamy white in the area of the fold).
This problem caused the cooling fan to stay on continuously so the tech elected to cut the wire to stop it from running, then sealed it off with a wire nut. I told him to wire it back and I'd just keep the breaker off when the oven/range was not in use, so he did. But not only did the fan run continuously at that point, the keypad now didn't work the controls to bake/oven properly (cooktop controls were fine).
As a result of that, he replaced the clock assembly as well as the keypad switch membrane, which allows the oven to function correctly again but the fan and oven light still stay on continuously. He phoned some help and was told that the newly replaced switch membrane was probably also bad, so he's going to order another one and hope that fixes the fan/oven light issues. I doubt that's the fix, but would like advice from y'all.
Thanks.
November 20th, 2010, 11:26 AM
Very interesting, but it sounds like your relay board in the back of your range is bad as well causing this.
Hate to see you invest all this money into a 14 year old range.
Here's the relay board for your model:
Manufacturer part number 12001689 is RepairClinic item number 400656
November 20th, 2010, 02:02 PM
Thanks for the reply. I hate it too, but, the only horse in town currently manufacturing and selling downdraft slide-in units is Jenn Air, and the new replacement for it is $2300. If I went with a traditional overhead vent and stove I'd also have a significant amount of money in the retooling of my kitchen for such a redesign.
One other thing I forgot to add to the OP was that the downdraft fan keypad still does not function at all. The downdraft fan will come on however, but only when you turn the griddle burners on the cooktop. Don't know if this makes your opinion change any. Are you fairly confident that the problem sounds like a circuit board/timer issue? I hate to throw good money after bad, but if that would fix it I'd still have less than $800 in it, and hopefully it would last another > decade.
November 20th, 2010, 02:21 PM
Yes, I'm sure.
We have a special program here, all parts you order from our links we post are returnable within 30 days for a FULL refund if they don't fix the problem.
November 20th, 2010, 02:27 PM
Yes, I'm sure.
That certainly seems more than fair. I'll have to talk to the lady now to see if she want to put more money into it.
I tried to do the "thanks" thing at the link in the bottom of the screen, but it said I don't have such perks yet.
Thanks again.
November 20th, 2010, 07:42 PM
Thats fine, thanks.
By farquand in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 1st, 2012, 08:51 AM
By yeldogt in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 14th, 2012, 10:34 PM
By terryjamaica in forum KitchenAid
Last Post: November 18th, 2010, 12:02 AM
By rgreensteinpa in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 2nd, 2010, 10:32 AM
By nameit23 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 19th, 2008, 07:15 PM
