December 15th, 2010, 02:20 PM
burners won't light Jenn air
can not get any of the burners to light -- the oven's and griddle light just fine. no clicking sound when you turn burrners on. light fine with a match. Where do I start?
December 15th, 2010, 07:28 PM
If ALL burners stopped working at the same time I would guess this
Re-ignition module Item #3
http://www.searspartsdirect.com/part...2015-00002.png
here is a place to order it
"73001323" Parts from RepairClinic.com
December 16th, 2010, 06:23 AM
the burners did not work when we moved into the house, so I an not sure of the history of them not working. Anyway to check it before ordering the part?
December 16th, 2010, 08:20 PM
Each burner valve has a switch attached to it. Item #15
Switch- ig (part #1071913) from RepairClinic.com
Turn off power to oven (unplug it or turn off circuit breaker)
Gain access to one of the switches for a non working burner,remove the two wires and jump them together (paper clip works great). Lay aside (make sure the paper clip is not touching anything (especially metal parts). Now restore power to the oven. If you now hear a constant clicking then THAT switch is bad. Try this procedure with ALL the non working burners.
By squirkie in forum Sears Kenmore
Last Post: January 19th, 2012, 05:45 PM
By PatrickM in forum Refrigerators & Freezers
Last Post: November 29th, 2011, 01:13 PM
By Phil413 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 20th, 2010, 06:42 PM
By billhig in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 31st, 2009, 09:31 AM
Last Post: October 5th, 2006, 09:39 PM
