Page 37 of 37 FirstFirst ... 27353637
Results 361 to 367 of 367
Thread: [FIXED] Maytag Refrigerator Model MSD2756DEB is not cooling properly
  1. #361
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    The cold control is the thermostat. The refrigerator must be running when you short L1 and Test (last two pins on the connector) The pins are labled on the board. Don't remove the connector. You can use a small screw driver.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  2. #362
    stovelady is offline Member
    Dec 2010
    New York
    Thank you oh so much!! I will try it and post the results.
  3. #363
    joepublic is offline Member
    Sep 2011
    uk
    Hi Rick - update on my query from a few weeks ago- the heater with the thermostate finally arrived yesterday. I defrosted the freezer and replaced the old heater. Then turned the timer screw clockwise as described to check whether the heater heats up - it doesn't. So as stated above, I looked at the timer before and that seemed to work OK (my post on previous page). So I am lost now - does the heater ONLY come on when the coil is frozen? Is that what the thermostat does - only switch the heater when its below certain temp? Do I need to check when its frozen rather than when its defrosted?
    Thanks for your help.
  4. #364
    Jul 2006
    That's correct, the defrost thermostat has to be below 40*F to close. Be careful advancing the timer in and out of defrost. If you don't give the compressor enough time to equalize the pressure before it starts you can damage it.
  5. #365
    Highwayman is offline Member
    Jul 2006
    Colorado
    I'm amazed this thread is still active and growing since I first posted to it in 2006. It has even earned top spot with a sticky!
    Model # MSD2756AEB
    Age; 12 years.
    Here's my current issue with the fridge. Everything works fine and the freezer runs about -10 degrees, give or take a few. The refrigerator side runs at 34 degrees. The beer is cold. The problem is it's at the end of it's adjustment. The refrigerator control is at 1 and against the stop. The freezer control is passed 1 and against the off switch. There is no more adjustment left so if the temperature drops, I'm screwed.
    I see there is a temperature control thermostat module and that would normally be my first guess. But there is something else I'd like to ask about.
    In the early years I had a well used extended warranty. During one of my annual visits from a repairman, one guy noted that the temperature control levers were setting around 6, which was the original settings when it was new. He didn't like that and somewhere under the cover at the top of the refrigerator side he tweaked something. I don't know what it was but after the dust settled the control levers ended up around 2. That was OK I guess, but over the years I've had to adjust them a little now and then until it's to the point of no adjustment left.
    If I knew what it was the guy tweaked, I'd try to un-tweak it before throwing money at the problem. If that adjustment is not on the thermostat module, replacing the module might not fix the problem. Any ideas what that adjustment might be? Otherwise, what do you recommend?
    Yes Highwayman, you posted to a very good and popular thread that earned a sticky.
    Sounds like your temperature control thermostat is bad.
    Manufacturer part number 61005651 is RepairClinic item number 1005345
    61005651
    www.applianceblog.com/manuals/16010154.pdf
    It tells you how to change it starting on Page 2-9
  7. #367
    Jul 2006
    There is an adjustment screw that the factory uses for calibration. It's not meant to be used by service techs to adjust temperatures as it can throw off the temperature swing considerably. There is a small hole in the face of the cold control with an arrow pointing towards colder. Don't turn it more than 1/8 turn counter clockwise and don't try it until it's the last resort because there is a good chance it won't work and will only make it worse. Here is the control you need:
    Temperature Control 61005651 Order now for same day shipping. 365 day return policy. RepairClinic.com
  1. Maytag fridge not cooling MSD2356AEW
    By richard tomasetti in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 12th, 2007, 12:18 PM
  2. maytag xrss287bb not cooling properly heater satying on
    By goza21 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 16th, 2007, 08:31 AM
  3. Maytag S/S refrigerator (MSD2756DEW) is not cooling properly:
    By mamtech in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 17th, 2006, 08:43 AM
  4. Maytag PTB195LGRW not cooling
    By rocksguy in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 9th, 2006, 09:36 AM
  5. Maytag Model MSD2732GRQ clicking noise/not cooling properly
    By nova817 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 26th, 2005, 04:01 AM
