Old December 14th, 2005, 01:04 PM
mefrank is on a distinguished road
Default Side by Side model MSD2756GES leaks all the time
The fridge leaks water from the freezer onto the floor all the time. It has frozen ice on the bottom of the fridge compartment and when you try to get water from the door it leaks like crazy!
The icemaker is overflowing whenever you get water from the door, but it leaks all the time even with the water option locked out. Any ideas?
Thanks all!
Michael
Old December 14th, 2005, 02:32 PM
It sounds like your defrost drain is clogged, here is a link to help you unclog it, if you wanted to do-it-yourself.
http://www.applianceaid.com/frig_leaking.html
Old December 14th, 2005, 04:05 PM
Thanks Jake, I will try this tonight.
Best,
Michael
Old December 14th, 2005, 05:10 PM
Thanks for your help, Jake. The drain was indeed clogged and now is draining fine. I did have two more problems I am hoping you can help me with.
Whenever you get water out of the door, the hose going into the icemaker has water run through it and it overflows the icemaker. Water still comes out of the door, but you get some additional water that spills out of the fridge. This still happens after cleaning out the drain.
The second problem is the flap that lets the ice out of the door. When you go to get ice, the things makes a sound like it wants to open, but nothing happens. Ice backs up into the chute since it doesn't open.
All your help is very much appreciated!
Michael
Old December 14th, 2005, 09:57 PM
The water inlet valve may be giving you trouble causing the water dispenser issue.
Then the solenoid, electronic board, or door spring/cam may be giving you the ice door flapper issue.
Check these links:
http://www.applianceaid.com/frig-dispenser.html
http://www.applianceaid.com/image/el...-dispensor.JPG
Old December 15th, 2005, 11:44 AM
Is this the item number I need to replace the water inlet valve? Also, the copper water line is going straight into the water inlet valve, is this the way it is supposed to be?
Michael
Old December 15th, 2005, 05:45 PM
On your model it looks like you have 2 water inlet valves, 1 that the copper hose connects, thats normal, then another one for the filter.
Try to confirm this by taking off the back access panel, and looking with a flashlight to see.
Also we will need the serial# so we find the right one,
Old December 18th, 2005, 08:48 PM
I know this is a Newbie question, but where is the serial number? I looked on the back and in the fridge itself. There is a piece of paper on the insode of the fridge with the model# thats it.
Michael
Old December 19th, 2005, 01:27 AM
On your model it should be on the top ceiling of the refrigerator, next to the model#.
This link may help you locate it as well:
Model Number Location Help
Old December 19th, 2005, 09:09 AM
Thanks jake, I found it. The serial is: 13487115ZZ
Maytag Model MSD2657HEQ fridge side warm robivi3 Maytag/Magic Chef/Admiral/Jenn-Air 5 June 9th, 2007 03:29 PM
GE side by side model gss22wgmdbb problem jpm1221 GE/Hotpoint 1 March 22nd, 2007 12:47 AM
Frigidaire side by side model #FRS26R4AW7 ailina1213 Frigidaire/Electrolux 3 December 22nd, 2006 11:33 PM
model FRS26ZNH side by side frstlght Frigidaire/Electrolux 3 July 22nd, 2006 06:03 PM
chemical odor in kenmore model 106 side by side refrig. joe s Sears Kenmore 1 October 29th, 2005 09:54 AM
