Results 1 to 2 of 2
Thread: Maytag Oven & Broiler not working
    Apr 2011
    Michigan
    Question Maytag Oven & Broiler not working
    Model Number: MGR5765QDW
    Brand: Maytag
    We bought this Maytag oven/range 5-6 years ago brand new. Yesterday, we cooked pizza in the oven with no problems at all. We went to fire up the oven today and ... nothing.
    All 4 top burners work great, the igniters fire properly, good gas flow, solid flame, etc.
    The oven, nor the broiler will work. When they are set, there's a brief click (like a relay) but there is no gas flow and no other sound.
    I grabbed the wiring diagram, popped the back off and dove in with my meter. There's a wiring harness on the back of the control module that has a red, yellow and 2 black wires. The 2 black wires attach to the same prong.
    As best I can tell, red controls the broiler value/igniter and the yellow controls the oven valve/igniter. It would seem very odd to me that both segments died at the same time... so I assume there's a single point of failure somewhere else. I'm thinking the control module.
    With the stove freshly plugged in and nothing "on" - the red/black combo on the control board reads at 125VAC. The yellow/black combo reads at 80VAC.
    If I activate the broiler, the relay clicks and the red lead drops to zero volts.
    If I activate the oven, the relay clicks and the yellow lead drops to zero volts.
    This seems really strange to me, like something must be all messed up in the control module. If the gas valves were "normally open" then gas would flow when the power went out... But, if the control module is messed up now, why isn't gas flowing when I'm getting voltage on the red & yellow wires?
    Please advise and thanks in advance for any help.
    Last edited by Backyard Mechanic; April 16th, 2011 at 11:22 AM. Reason: 1st Edit: Verbage corrected. 2nd Edit: Additional question.
    Yes, the problem is the clock oven control board.
    Here's the clock oven control board for your model you can order here:
    Manufacturer's Number: 74009150
  1. Oven and Broiler not working
    By parrier in forum GE/Hotpoint
    Last Post: January 9th, 2011, 01:54 PM
  2. [FIXED] Frigidaire Gas Oven & Broiler Not working
    By rdowler in forum Frigidaire/Tappan/Electrolux
    Last Post: August 29th, 2010, 11:42 PM
  3. FIXED: Broiler and stovetop working, but oven not heating in bake mode
    By JKabro96 in forum Sears Kenmore
    Last Post: August 21st, 2010, 02:34 PM
  4. Maytag Oven and Broiler Won't Light....ignitor checks out OK
    By e5791 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 16th, 2010, 11:42 AM
  5. Maytag MER5755QAW oven not working
    By kristinaks in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 28th, 2009, 09:46 PM
