Results 1 to 10 of 15
Thread: [FIXED] Maytag LSG7804AAE Stack Washer not working
    Rc10t4 is offline Member
    Apr 2011
    Los Angles
    Default [FIXED] Maytag LSG7804AAE Stack Washer not working
    Model Number: Lsg7804aae
    Brand: Maytag
    Washer just stoped working timer will run spin and rinse but will not fill if you open the lid washer does shut down
    There should be a fuse inside the washer on the side panel, once you remove the front panel, that fuse may be blown, thus won't fill with water.
    If it is blown, then you can not simply replace the fuse, but you'd need to change the lid/latch switch assembly.
    For that: Whats the serial# of your stack washer? They make two different ones for your model, depending on your serial#.
    Apr 2011
    Los Angles
    Here is the number 16211441QH
    Fuse was bad put a new one in it went then tried a jumper and it still not working?
    Just as a side note washer does run in spin and when you lift the lid it does shut down the washer
    Like I said, you simply can't replace the fuse, this lid switch has 2 switches in it, one for the water fill and agitate and one for the spin.
    Here's the lid switch assembly for your model you can order here:
    Manufacturer part number 12001514 is RepairClinic item number 400492
    Apr 2011
    Los Angles
    Thumbs up Thanks
    Thanks got the part yesterday and we are good to go thanks so much
    Excellent, glad to hear its back to normal.
    tmol is offline Premium Member
    Jan 2011
    florida
    hello, i have the same problem blows fuse serial # 15932203u5 model # lse7806ace the lid switch assy is the problem ?
    Yup, and yes your model/serial number use the exact same lid switch assembly I posted above.
    Apr 2012
    Hawaii
    Hello,
    i too have the same problem... my serial number is 26619527JT. I would appreciate your help. Thanks!
    Apr 2012
    Hawaii
    Just realized my part number is different from the OP's.... Mine is LSE7804ACE. But i have the same symptom.
    Quote Originally Posted by retrodirective View Post
    Hello,
  1. Maytag Bravos Washer OL error
    By klehman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 18th, 2010, 03:46 PM
  2. Maytag Washer MAV505&AWW Still Leaks HELP!
    By zeravlak in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2008, 12:39 PM
  3. Maytag washer fills with water and then nothing.
    By g206276 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 14th, 2007, 04:54 PM
  4. Maytag performa washer fills...and that all, folks!
    By msubobcats in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 3rd, 2007, 06:41 PM
  5. MAYTAG NEPTUNE WASHER CONTROL PANEL UNRESPONSIVE
    By kpd in forum Maytag/Jenn-Air Reviews
    Last Post: July 31st, 2007, 10:45 AM
