Results 1 to 4 of 4
Thread: Gas Oven not heating
    johnc151 is offline Member
    Dec 2005
    Connecticut
    Default Gas Oven not heating
    My Magic Chef model 6498vvv gas range is not heating properly. The ignitor is working and the element lights. If I set the tempature to 350, the oven gets to 250 and cycles off. The display shows no error codes. Any help would be greatly appreciated.
    John
    Your thermostat may be not calibrated, or the sensor has gone bad.
    Here is a link for more information on it:
    http://www.applianceaid.com/gas.html
    You can probably go to www.maytag.com to download an user manual if you don't have yours, to help you calibrate the oven.
    Dec 2005
    Connecticut
    Default I don't know if this has something to do with the problem or not
    Also on this range I have noticed that it takes the oven burner about two minutes to light? And should the igniter stay on even after the burner is lit?
    thanks again
    John
    It should light in about 90 secs. 2 minutes may be abit long, which could mean the igniter is starting to go out.
    Yes, the igniter will be on the whole time the flame is heating the oven.
  1. Kenmore 70 series gas Dryer not heating right
    Last Post: February 12th, 2007, 08:14 PM
  2. Whirlpool super capacity 465 gas oven not lighting
  3. Kenmore gas oven 362.72295790 oven won't light
    By bandit1trucking in forum Sears Kenmore
    Last Post: November 20th, 2006, 12:36 AM
  4. Magic Chef Gas Oven - 3110KRW
    By svwilly in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 29th, 2006, 05:45 AM
  5. Maytag Gas Oven - oven startup/popping problems
    By kpd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 11th, 2005, 11:37 AM
