July 2nd, 2011, 10:59 AM
Maytag Performa
Maytag Performa Washer Model # PAVT244AWW Started making noises like bearings or belts and then stopped before the first rinse cycle. Burning smell started so I unplugged it. The machine was set on the oversize setting when this happened. I did not try to restart it due to the burning smell. Any suggestions?
July 2nd, 2011, 11:05 AM
Tilt the washer back and take the belt off underneath it, then turn all 3 pulleys both ways, and see if they all turn freely, possibly your water pump bearing went out, most common to happen on this model.
Here's the water pump for your model:
Drain pump assembly. *Redesigned - no mounting plate - pump mounts directly to base of the washer.
Manufacturer part number 35-6780 is RepairClinic item number 1480294
By Tagman886 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 26th, 2009, 05:34 PM
By tarheelgal5420 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 12th, 2007, 10:05 AM
By walkingonthesun in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: July 18th, 2007, 10:44 AM
By DBoone in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 20th, 2006, 12:17 AM
By mcnultyjj in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 20th, 2006, 04:54 PM
