Results 1 to 4 of 4
Thread: How to clean water/ice dispenser tubing with vinegar?
    texasnutmeg is offline Member
    Jul 2011
    Texas
    Default How to clean water/ice dispenser tubing with vinegar?
    Model Number: MSD2651KES
    Brand: Maytag
    We have a Maytag refrigerator and the water and ice cubes have started showing floating goop upon dispensing.
    We followed the directions here:
    How to Clean a Water Dispenser on a Refrigerator Door | eHow.com
    to clean out the system. However, after disconnecting the water supply line and trying to pour in the vinegar (step 2), we can not get the vinegar to go into the water reservoir. It fills the first tubing and then stops.
    Any suggestions on how to get more than a few tablespoons of vinegar to go in? We tried a syringe but it just leaked all over the floor. Or any other ways to clean the system out?
    Thank you.
    Ok, I'm my 20 plus years of appliance repair I've never ever cleaned out the plastic water line with vinager or anything else, as I knew the results would still not be good, as you see on yours.
    There's not a way to clean out that water tank that I'm aware of. From all the ones I've run into like this I always replace the water tank assembly.
    Here's the water tank assembly for your model you can order here:
    Manufacturer's Number: R0131625
    Its fairly easy to change, you just cut the plastic water lines from the outside of the back of your refrigerator before they go into the refrigerator section, make sure you have some slack, don't cut the lines too close to where the go into the refrigerator section from the back.
    Then you remove the tank, should be 1 or 2 screws holding it in place, then install the new tank, and use the compression fittings that come with the new tank to reconnect the 2 water lines you cut.
    Thats it.
    Its #11 here, its located behind your crispers in the lower half of your refrigerator section:
    Jul 2011
    Texas
    Thanks!!
    Glad to help.
  1. Another GE Water/Ice Dispenser Problem
    By billp44ruby in forum GE/Hotpoint
    Last Post: March 20th, 2011, 12:08 PM
  2. no power to water/ice dispenser?
    By n11 in forum Frigidaire/Electrolux
    Last Post: November 20th, 2006, 08:29 AM
  3. Water Dispenser Tubing has "green film"
    By FourMcGrews in forum Whirlpool/Roper/Estate
    Last Post: May 22nd, 2006, 11:54 PM
  4. Replacing tubing for ice dispenser Amana
    By John C in forum Amana
    Last Post: February 5th, 2006, 07:26 PM
  5. frigidaire water/ice dispenser inop
    By exwoodsplitter in forum Frigidaire/Electrolux
    Last Post: January 16th, 2006, 10:18 AM
