October 29th, 2011, 01:16 PM
#11
Before I order the part number 44 grommet, do you think I need the 24 or the 45? Id rather get it everything that needs done once i have it apart.
October 29th, 2011, 07:25 PM
#12
The drain tube #45 is No Longer Available, the clamp #24 is, so its your choice to get it or not, its only a couple dollars more.
October 31st, 2011, 07:42 AM
#13
I just wanted to say in the past 3 days there as been zero water ice build up in the bottom of the freezer, I think the snake has solved the problem good enough to where I dont need the grommet yet, but I will keep an eye on it and if i see an issue i know what to do. So for now im just going to wait.
THanks so much for ur help!
October 31st, 2011, 12:30 PM
#14
Excellent, sounds good.
By gregger77 in forum Sears Kenmore
Last Post: December 4th, 2011, 10:15 AM
By Frederick in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 1st, 2011, 08:38 PM
By Ford in forum Sears Kenmore
Last Post: May 2nd, 2011, 05:30 PM
By ihellman in forum Sears Kenmore
Last Post: February 26th, 2011, 02:16 PM
By bkmason in forum Sears Kenmore
Last Post: May 28th, 2007, 09:00 AM
