Results 1 to 3 of 3
Thread: More Ice Maker Issues
    jpbulldog1979 is offline Member
    Jun 2011
    Simi Valley, CA
    Default More Ice Maker Issues
    Model Number: JSD2789DEW
    Brand: Jenn-Air
    My ice maker seems to be occasionally trying to push cubes out before they are frozen. This is leading to ice buildup on the fingers and is leading to hollow ice cubes and jammed cubes in the ice maker causing ice to stop until the jam is noticed and cleared. Before I replace the ice maker I wanted to ask if this was indicative of an ice maker problem, or if there is a control board somewhere that would be causing the problem. Thanks again for all your help.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    This happens sometimes if the ice maker doesn't get enough water. I think you're correct and it's the ice maker. Do you have a water filter and if so when was it last replaced? Here is the ice maker for your model:
    Ice Maker Assembly D7824706Q Order now for same day shipping. 365 day return policy. RepairClinic.com
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jun 2011
    Simi Valley, CA
    Thanks for the filter comment. I did get a new filter and it was obviously different flow-wise. It must have happened slowly, because I remembered after the new filter was in that it didn't always take as long to fill the water cups. It has been working perfectly with big ice cubes and fast water flow for 2 days now. Thanks for the catch.
    Justin
  1. [FIXED] Ice Maker Issues
    By jpbulldog1979 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 26th, 2011, 10:17 PM
  2. Kitchen Aid ice maker issues
    By madman13 in forum KitchenAid
    Last Post: May 11th, 2009, 10:52 PM
  3. Kenmore w/new ice maker has issues
    By skregal in forum Sears Kenmore
    Last Post: August 24th, 2008, 09:03 PM
  4. More Ice Maker Issues
    By bavarian in forum KitchenAid
    Last Post: May 27th, 2006, 08:03 PM
  5. ice maker issues
    By chesson in forum Sears Kenmore
    Last Post: April 19th, 2006, 11:40 PM
Tags for this Thread
