Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Fridge STILL warm and freezer fine
  1. #11
    pdsullivan is offline Member
    Oct 2011
    OK
    Default Rick
    Thanks. I ordered the part and we'll see how that goes.
  2. #12
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    OK Sounds good, keep us posted
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  3. #13
    Oct 2011
    OK
    Default Rick
    Got the fan in and working well! Have had to turn freezer and fridge down as too cold in fridge and freezing stuff. Water and ice dispenser not working ow as frozen? It worked for a day or so after installing fan. Suggestions?
  4. #14
    Jul 2006
    If you had the controls turned way up when you replaced the fan motor, the water line or filter is most likely frozen. Take the filter out and try to defrost it. Look for ice in the line with the filter out. There's a good posibility the water resivoir or coil for the dispenser is also frozen. Turn your controls down and wait for any ice in the line to melt. It may take a day or two.
  5. #15
    Oct 2011
    OK
    Thanks, I will try it.
  6. #16
    Jul 2006
    Sounds good. Keep us posted
  7. #17
    Oct 2011
    OK
    Rick, my filter is thawed and had temp down for coue dye prior to texting you. Still unable to get water from line.
  8. #18
    Jul 2006
    OK, You'll need to find out where the blockage is by process of elimination of each section. You'll test each section the same way. It helps if you have someone to work the dispenser while you disconnect each section to test it. Start with disconnecting the water dispenser water line at the water valve and use a bucket to catch the water and see if the water comes out of the valve. First section is water line to water filter. Then water filter to the quick disconnect under the freezer door lower hinge and then out the dispenser.
  1. [FIXED] Top freezer working fine, bottom fridge warm
    By JanetC in forum Sears Kenmore
    Last Post: September 21st, 2011, 10:00 PM
  2. [FIXED] Kenmore fridge warm (But freezer works fine.)
    By pjstock in forum Sears Kenmore
    Last Post: September 4th, 2011, 07:03 AM
  3. GE Fridge getting Warm / Freezer works fine
    By J&T in forum GE/Hotpoint
    Last Post: August 14th, 2011, 01:12 PM
  4. [FIXED] Fridge is warm, freezer is fine
    By pucara in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 11th, 2010, 06:22 PM
  5. Hotpoint Freezer fine fridge warm
    By moto52000 in forum GE/Hotpoint
    Last Post: January 18th, 2010, 05:20 PM
