October 27th, 2011, 12:48 PM
Fridge STILL warm and freezer fine
Bottom freezer unit off for 2 yrs and in closed up house. Turned unit on and after a day, freezer cold and fridge warm. Found mouse nest in evaporator fan-cleaned out and working fine. Still warm. Freezer fan working and damper visualized opening and closing. Condensor working. No frost build up. Unit 6-7 yrs old. Fridge STILL warm!! What next?
Reason: Incorrect age posted
October 27th, 2011, 02:58 PM
Found mouse nest in evaporator fan-cleaned out and working fine?
The evaporator fan is inside the freezer, you probably mean condenser fan, thats in the back next to the compressor.
Ok, so if the compressor and both the condenser fan and evaporator fan are all running and its not freezing inside the freezer but just cool, that means you have a sealed system/compressor issue that you'd need to get a tech. to come out for that, thats not consumer serviceable.
October 27th, 2011, 04:45 PM
The freezer is working very well-setting on 4 and ice cream is rock solid. I've watched the damper open and close, both fans turning. Do you think it is still the seal?
October 27th, 2011, 11:45 PM
What seal? I didn't mention a seal.
Check your door gaskets to make sure they are sealing tight against the cabinet when the doors are closed. Make sure there is no rips in either door gaskets.
October 30th, 2011, 04:47 PM
STILL warm
I checked the gasket seal around the doors and all is fine. The Evaporator coils appear fine, fan working, damper opening and closing, condenser working as well as fan. I do not feel any air coming from the damper with the fans turning. The freezer is at 4 setting and freezing ice cream well. The refrigerator is at 2 (had it at 4 before) and still warm. What else might it be?
October 30th, 2011, 05:02 PM
Originally Posted by
pdsullivan
Tell me exactly what they looked like. If possible, take a picture of the coils and post it here. Once I see the coils, I'll be able to tell if they're fine, if there's a defrost issue , or a sealed system issue.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
November 5th, 2011, 09:37 PM
Rick, the evaporator coils are clean and without any ice build up. I am attaching a couple photos.
I hope these will help you to help me!
November 5th, 2011, 09:55 PM
Depending on the conditions when those pictures were taken; If you took the pictures when the compressor was running and you didn't manualy defrost it, the evaporator is starving. That indicates a sealed system problem. They should be white with a very light coat of frost on all the coils.
November 6th, 2011, 06:00 PM
Rick, I took those pictures after unplugging fridge and getting back off and all had defrosted. i am attaching new photos that show coils without unplugging unit at all. I also noticed that the evaporator fan was not spinning with or without fridge doors open. When I spun the manually, it kicked in and was spinning on it's own but not much air. It did stay on. Here are photos.
November 6th, 2011, 06:10 PM
That looks much better and very normal for having a bad fan motor. Here is the one for your machine and that will fix the issue.
Evaporator Fan Motor 12002744 Order now for same day shipping. 365 day return policy. RepairClinic.com
It's common for this style fan motor to fail
By JanetC in forum Sears Kenmore
Last Post: September 21st, 2011, 10:00 PM
By pjstock in forum Sears Kenmore
Last Post: September 4th, 2011, 07:03 AM
By J&T in forum GE/Hotpoint
Last Post: August 14th, 2011, 01:12 PM
By pucara in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 11th, 2010, 06:22 PM
By moto52000 in forum GE/Hotpoint
Last Post: January 18th, 2010, 05:20 PM
