Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Maytag Model No AFC2033DRQ with freezer / frig not cooling
  1. #11
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Yes, remember it needs to be below forty degrees.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  2. #12
    richardsg is offline Member
    Nov 2011
    san diego
    the results of the defrost heater ~ 28 ohms and defrost thermostat ~ 0.1/0.0 (i believe that is continuity both). Note: the check the thermostat as fast as I could to ensure less than 40 degrees
  3. #13
    Jul 2006
    Sounds like both the heater and defrost thermostat are good. That just leaves the control board. Click on the link above the part. If it doesn't work you have 365 days to return it. The control board wil get it defrosting again and fix your problem.
  4. #14
    Nov 2011
    san diego
    Rick
    Would you have any instructions for removing / installing the control board? I can see the two clips holding the housing up, but I don't want to break anything (ie light housing) during disassembly.
  5. #15
    Jul 2006
    Release the two in the back and then slide the control back to release the two in the front.
  6. #16
    Nov 2011
    san diego
    Got it installed. Hopefully, that will do the trick. Thanks for the help.
    It was a surprise to unsnap then snap the refrig back together like a child's toy (What ever happen to using screws?).
  7. #17
    Jul 2006
    Screws cost money don't you know!
  1. Whirlpool Gold, freezer cold, frig not cooling
    By oltmann in forum Whirlpool/Roper/Estate
    Last Post: August 10th, 2011, 10:56 PM
  2. Kenmore Frig and Freezer Not Cooling Enough
    By udel in forum Sears Kenmore
    Last Post: June 25th, 2011, 10:14 AM
  3. Whirlpool Frig/freezer not cooling properly
    By lilifred in forum Whirlpool/Roper/Estate
    Last Post: November 30th, 2009, 12:44 PM
  4. [FIXED] Freezer working/Frig not cooling
    By bamadave in forum Frigidaire/Electrolux
    Last Post: September 16th, 2009, 10:26 PM
  5. Frig or Freezer not cooling good
    By Addiction in forum GE/Hotpoint
    Last Post: August 15th, 2005, 05:45 PM
