Results 1 to 10 of 17
Thread: Maytag Model No AFC2033DRQ with freezer / frig not cooling
    richardsg is offline Member
    Nov 2011
    san diego
    Default Maytag Model No AFC2033DRQ with freezer / frig not cooling
    Model Number: AFC2033DRQ
    Brand: Maytag
    I have a 5 year Maytag frig Model No AFC2033DRQ (side by side with freezer on the bottom) were the freezer is working / but the frig section is not. I have looked at some of the posts and found some good info:
    Beside this link is there any additional tasks I should do on my frig
    BTW: This the freezer is working / but the frig section happened once before (about a 1 year ago), but after two days the frig begin to work normally.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Check and make sure both fans are working. The evaporator fan is in the freezer section and the condenser fan is by the compressor. Make sure the condenser coils are clean and air flow across them is not restricted. See if the compressor is running. Frost or ice on the back wall of the freezer section would indicate a defrost problem and requires further testing.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    san diego
    The evaporator fan (in the back is running), and a slight layer of frost on the back wall of the freezer. I will look for ice on the condenser coils tomorrow.
    Nov 2011
    san diego
    The condenser fan (in the back is running), and a slight layer of frost on the back wall of the freezer. There is no ice on the coils, and that middle door divider (on the left door) is hot to the touch.
    Jul 2006
    You have a defrost issue. You'll need to remove the back wall and you will see ice on the coils. Use a meter to check the defrost heater and defrost thermostat for continuity. If both check good then you'll need to replace the control board. Check the defrost thermostat first while it's covered with ice. It needs to be below 40*F to read closed. With the back wall off defrost the evaporator with a hair dryer and get all the ice out. Then it will work for a while untill you replace the part that is bad. Here is all three parts:
    Heating Element 67002493 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Defrost Thermostat 12001937 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Control Board 12868513 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2011
    san diego
    Opened up the inside of the freezer, and found the ice. Checked for continuity on the defrost heater and found none. Forgot to check the defrost thermostat. Should I only replace the defrost heater and thermostat (since inside is open, being defrosted)? Would replacing the defrost thermostat be easy? the defrost heater looks pretty stairforward.
    thanks for your help.
    Maytag Model No AFC2033DRQ with freezer / frig not cooling-wp_000463.jpg
    Jul 2006
    Just replace the heater. Defrost the evaporator with a hair dryer and get all the ice out.
    Nov 2011
    san diego
    Rick, I made a mistake. The defrost heater has continuity. Not sure about checking the defrost thermostat
    Jul 2006
    The defrost thermostat needs to be below 40*F to close. If it's below 40* and reads open or shows infinite resistance, it's bad.
    Nov 2011
    san diego
    I'm not sure how to check the thermostat. Would I simply unplug it's connect and do a continity check there?
  1. Whirlpool Gold, freezer cold, frig not cooling
    By oltmann in forum Whirlpool/Roper/Estate
    Last Post: August 10th, 2011, 10:56 PM
  2. Kenmore Frig and Freezer Not Cooling Enough
    By udel in forum Sears Kenmore
    Last Post: June 25th, 2011, 10:14 AM
  3. Whirlpool Frig/freezer not cooling properly
    By lilifred in forum Whirlpool/Roper/Estate
    Last Post: November 30th, 2009, 12:44 PM
  4. [FIXED] Freezer working/Frig not cooling
    By bamadave in forum Frigidaire/Electrolux
    Last Post: September 16th, 2009, 10:26 PM
  5. Frig or Freezer not cooling good
    By Addiction in forum GE/Hotpoint
    Last Post: August 15th, 2005, 05:45 PM
