Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Maytag mfd2560hes not cooling, fan turns, constant clicking noise
  1. #21
    timrybak is offline Member
    Nov 2011
    South Carolina
    We left the door open and the back wall unassembled all night. It was bone dry this morning.
    I haven't noticed this personally, but my wife mentioned that it is cycling really fast. She says she heard it cut on, run for a minute, then cut back off. So, while I know the fan is working, maybe it's not being told to work? Could the evaporator thermostat in the freezer be the issue?
  2. #22
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    Do you have all together, back wall on? It's not usual to have two seperate problems. You replaced the heater and defrosted it ,should be working. You might need to have a tech look at it.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
  3. #23
    Nov 2011
    South Carolina
    Resolution:
    Had a tech come out. Told him everything I had done, looked at, tested, etc. He pulled the back panel off of the freezer and immediately determined the problem to be the evaporator fan motor. While the fan was turning, it wasn't turning nearly fast enough. Having never seen what "normal" looks like, I had no idea. So, $40 and a new fan motor later, my fridge is back at 40 degrees, and my freezer is at 0.
    Thank you for all your help!
  4. #24
    Jul 2006
    Quote Originally Posted by timrybak View Post
    I've only see that happen a few times. Usualy they stop working all together. Well, glad it's fixed. You did an excelent job testing. Well done!
  1. Maytag MFD2560HES Loud noise upon starting cycle
    By famousredhead in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 11th, 2011, 10:20 AM
  2. Constant clicking on new GE gas range top
    By cmreds in forum GE/Hotpoint
    Last Post: September 15th, 2006, 04:45 AM
  3. Maytag range constant clicking
    By mickeyg13 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 12th, 2006, 04:06 AM
  4. Constant clicking noise when unit is in operation
    By section9 in forum Sears Kenmore
    Last Post: February 25th, 2006, 07:33 PM
  5. Maytag Model MSD2732GRQ clicking noise/not cooling properly
    By nova817 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 26th, 2005, 04:01 AM
