Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Maytag mfd2560hes not cooling, fan turns, constant clicking noise
    timrybak is offline Member
    Nov 2011
    South Carolina
    Default Maytag mfd2560hes not cooling, fan turns, constant clicking noise
    Model Number: mfd2560hes
    Brand: Maytag
    Woke up this morning and the temp inside the refrigerator was 70 degrees. The freezer section is still plenty cold. The appliance is a Maytag mfd2560hes, french door style, freezer on the bottom.
    Symptoms... First thing I noticed was that the fan wasn't running and there was a click click click sound coming from the back. It clicked for maybe 10-30s? I pulled the fridge out and removed the back panel, but it seems to be coming from above the removable panel on the left side (if you are looking at the back of the fridge). I do know that while I was down looking at the dust balls, the fan did come on and run with no problem for a bit. I checked the copper coils coming out of the compressor, and the seemed pretty clean.
    rickgburton's Avatar
    Jul 2006
    Murray, Utah, United States
    The clicking you heard was probably the overload on the compressor. Remove it and shake it to see if it rattles. Look on the compressor for a name like Embraco.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Nov 2011
    South Carolina
    Please forgive my ignorance when describing this. I opened the black panel on the back of the fridge and detached the stuff that was attached to the compressor. There was a black piece that had 2 blades on it. I took that off and shook it and there was no noise. Then, I disconnected the wire harness and pulled off a white block. I shook it and it had a tiny rattle, like maybe the metal that the compressor posts went into giggling a little.
    Tonight I mentioned all of this to my wife, and she said she hadn't heard any of the clicking since early this morning.
    Also, there was no name on the compressor, but it had a sticker with a blue indian head on it with two sets of numbers. On top is TP141-AR-229-B8, and on bottom is TPG1370YXA.
    Jul 2006
    I think you have a bad start device. Replacing it will probably fix the refrigerator:
    Start Device 67005560 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Nov 2011
    South Carolina
    Last thing before I buy this part... I don't think I mentioned that the freezer is unaffected. It is still cooling with seemingly no issues. Could that part still be the issue?
    Jul 2006
    Take the temperature of the freezer and see what you get. Should be 0.
    Nov 2011
    South Carolina
    My wife just temp'ed the freezer at 3 degrees. It is currently set to a level of 6 (max temp setting is 7).
    Jul 2006
    Still hearing the clicking sound? Set both controls at midway then take a temperature reading. Fresh Food should be around 38 and freezer should be around 0
    Nov 2011
    South Carolina
    I remember hearing the clicking sound this morning... went on for a few minutes before stopping. The fridge is still at room temperature. I found a local appliance part store that had that part, so I picked one up at lunch. I will replace it tonight and let you know how it goes.
    We've been having an issue with the ice maker where we weren't getting any ice and I could feel liquid in the ice cube trays. That was maybe a month ago? I temped the freezer then at about 16 degrees, so I moved it from 5 to 6. That got the ice maker going, but now I am thinking that might have been an early warning sign?
    Thank you for your help thus far!
    Nov 2011
    South Carolina
    No dice. I replaced that part this evening. It's been an hour and a half or so, and it is still 70 degrees in the fridge. What else could it be?
  1. Maytag MFD2560HES Loud noise upon starting cycle
    By famousredhead in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 11th, 2011, 10:20 AM
  2. Constant clicking on new GE gas range top
    By cmreds in forum GE/Hotpoint
    Last Post: September 15th, 2006, 04:45 AM
  3. Maytag range constant clicking
    By mickeyg13 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 12th, 2006, 04:06 AM
  4. Constant clicking noise when unit is in operation
    By section9 in forum Sears Kenmore
    Last Post: February 25th, 2006, 07:33 PM
  5. Maytag Model MSD2732GRQ clicking noise/not cooling properly
    By nova817 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 26th, 2005, 04:01 AM
