November 11th, 2011, 09:39 AM
ice maker not making ice
My Maytag refrigerator is not making ice. It is model # MFD2560HEW. Any help will be appreciated. The ejector arm fingers are straight down if this helps.
November 11th, 2011, 09:52 AM
Remove the wire connector from the back wall and with your meter set to check volts, read between the black and the white wire. Hold the door switch in. No volts, check the door switch. 120 vac, replace the ice maker.
Door Switch Assembly 12002646 Order now for same day shipping. 365 day return policy. RepairClinic.com
Ice Maker Assembly D7824706Q Order now for same day shipping. 365 day return policy. RepairClinic.com
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
By Brandyn in forum Whirlpool/Roper/Estate
Last Post: December 7th, 2010, 07:26 PM
By khazouri in forum KitchenAid
Last Post: May 25th, 2010, 03:24 AM
By sard in forum Sears Kenmore
Last Post: June 13th, 2009, 09:11 AM
By tammie in forum Sears Kenmore
Last Post: July 26th, 2007, 03:42 PM
By tedsgirl83 in forum Refrigerators & Freezers
Last Post: June 24th, 2005, 10:56 AM
