Results 1 to 2 of 2
Thread: Side by side too cold both sides
    kah5683 is offline Member
    Nov 2011
    Chicago
    Default Side by side too cold both sides
    Model Number: LRSC20A AM01A
    Brand: Maytag
    Age: More than 10 years
    Refrigerator is about 30 years old. Has been relegated to garage duty for years. The last few years it alternates between too cold and too warm. This last summer I bought a freezer thermometer and a separate thermometer for fridge. Adjusted dials for fridge and freezer until temperatures in both were within range - it took both dials to be at their lower/lowest settings. I kept the thermometers monitoring each and they were fine for a few months until the temperature here in Chicago area started to cool off (today around 40) Now the freezer and fridge are COLD: don't recall exact numbers, but freezer way below normal range, and the fridge around 26 degrees or so.
    This summer, I also pulled back the fridge from wall and cleaned underneath for the first time in years. Not sure if I hit all the right spots.
    I took out the fridge temperature control from behind the the fridge control dial (the freezer dial just opened and closed a small door to freezer). I used my multimeter to check. Off was infinity and 11 (max) was 0. Guy at parts place said I had to check the part cold, so I put in fridge and checked after a while, and it was the same.
    This is a common problem during the cold winter months with refrigerators in garages, just do a search for the word: garage
    and the results are many.
    Usually it will perform better if the outside garage temp. does not fall below 50.
    Here's a good thread that talks about it:
    garage refrigerator questions
  1. GE Side by Side not cooling on both sides
    By RyanV in forum GE/Hotpoint
    Last Post: February 7th, 2011, 09:14 AM
  2. GE side by side warm both sides
    By flstf in forum GE/Hotpoint
    Last Post: September 30th, 2010, 12:22 AM
  3. [FIXED] Magic Chef Side-by-Side Freezer cold but Refrigerator side warm
    By k2bzee6 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2010, 09:25 AM
  4. Replies: 7
    Last Post: June 28th, 2010, 10:14 AM
  5. Replies: 3
    Last Post: October 13th, 2009, 08:14 PM
