November 17th, 2011, 02:02 PM
Maytag MSD2756DEB Icemaker that won't function
I have a Maytag MSD2756DEB Icemaker that won't function. Removed the unit....made sure it was dry and clear....water comes through the door so I doubt that could be a water issue. Does it sound like I need a new unit? The arm is down so the maker is on....I did the paperclip jumper wire trick...nothing. Ideas?
November 17th, 2011, 03:45 PM
Originally Posted by
JimRDwin
Removed the unit....made sure it was dry and clear...water comes through the door so I doubt that could be a water issue.
When you removed the ice maker, was there ice in it and it won't dump it or was it empty (no ice). If it was empty you'll need to check the water valve
JimRDwin
Tell me what trick you did. Maybe you didn't do it right 'cause you didn't get a shock.
OWNER RICK'S APPLIANCE REPAIR
REFRIGERATION SPECIALIST
November 18th, 2011, 11:29 AM
MAytag MSD2756DEB Ice MAaker
Thanks for the response....I toiok a aperclip and shaped it into a U and put tape in the middle so I didn't get a shock...and inserted it into the N and V holes...I gues to reset the maker. Nothing happened...should I try other holes? I had removed the maker it self....dried it off completely using a hair dryer....and checked the hoses to be certain there was no frozen water anywhere....and the wire to the left is all the way down in the on position.
After thinking about this last night I waonder if it is the valve that goes to the ice maker. I read that where the water line comes in it separates into two lines...one water for drinking and the other for the icemaker. The water works fine...but there is no water to the ice maker.
Thanks, anyhting would be appreciated.
Have a nice afternoon...and Holiday!
Jim
November 18th, 2011, 01:23 PM
Maytag MSD2756 IceMAker issue
Sorry Rick, I did not respond to your question....yes, when I removed the icemaker form the freezer there was stil ice in it....that is why I iused the hair dryer.
Thanks, Jim
November 19th, 2011, 08:33 AM
OK if there were ice-cubes in the ice maker, the water valve is most likely good. If you want to force cycle the ice maker to start a harvest mode, try this; take a 2" piece of insulated wire and strip a half inch off each end. Bend it in the shape of a "U" Locate and short holes "T" and "H". Once the harvest cycle starts, remove the wire. Sounds like the ice maker is bad.
http://www.repairclinic.com/PartDeta...824706Q/915772
November 30th, 2011, 11:18 AM
As of this moment I am certain it is the ice maker unit itself. I have trouble shot this puppy as far as I can..and from talking to other tehnicnas they agree....but I don't know if I am ready to spend the $100 to geta new one,
Thanks for al of your advise...it is appreciated.
Jim
November 30th, 2011, 12:26 PM
Did you try to force cycle it already?
November 30th, 2011, 02:21 PM
Maytag Ice Maker
Thanks for the response....I tried the cycling by using the paperclip jumper at the T and H holes....but it didn't cycle....or for that matter make any noise like it was even ready or thinking about cycling. Are there any other methods of cycling using the other ports?
Thanks, Jim
December 1st, 2011, 01:29 AM
Nope, that's it. The power module is bad.
By suk in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 23rd, 2011, 07:21 AM
By RomZilber in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 8th, 2007, 09:33 AM
By sel_san_jose in forum Dishwashers
Last Post: December 11th, 2006, 10:55 PM
By msmonday in forum Whirlpool/Roper/Estate
Last Post: March 22nd, 2006, 08:31 AM
By JVB in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 27th, 2005, 04:04 AM
