Results 1 to 6 of 6
Thread: Electric range control panel or electronic oven control?
    WhyNot is offline Premium Member
    Jul 2008
    Inverness, CA
    Question Electric range control panel or electronic oven control?
    Model Number: JES9800BAS
    Brand: Jenn-Air
    My customer says the control panel started to malfunction a while ago, i.e.. some of the touch pads wouldn't respond. Now none of them respond. The display is lit and shows "Power failure," which makes sense since he did turn power off and back on.
    Here's my question: Is the problem with the control panel or with the electronic oven control? Which should I replace?
    When the control panel buttons start not responding its usually the control panel itself thats bad.
    Manufacturer's Number: W10206087
    The clock still lights up? But you can't set anything on it due to the control panel buttons not working?
    Jul 2008
    Inverness, CA
    Yes, that's right. The clock lights up, but none of the control panel buttons work. So based on what you say, I'm going to order the control panel and not the EOC.
    Thanks for responding.
    Yup, exactly.
    dflick is offline Member
    Jan 2012
    Fruitvale
    Yesterday our Jenn Air gas convection oven electronic panel stopped responding to touch. After searching the internet I was dismayed to learn that this is a common problem with the Jenn Air product.
    In hopes of resetting the panel we unplugged the unit for a few minutes - plugged it back in and the electronic control panel worked just fine. We will see how long this "fix" lasts.
    Ok, yes, because usually if it does it once, it will do it again.
  1. Whirlpool Electric Range Control Panel Does Not Work
    By winzy in forum Whirlpool/Roper
    Last Post: August 29th, 2011, 11:53 AM
  2. Replies: 3
    Last Post: April 29th, 2011, 09:40 PM
  3. MayTag Precision Touch Control 700 Electric Smooth Top Control Panel
    By chris.c2005 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 2nd, 2008, 11:15 PM
  4. Jenn-Air electronic control panel
    By triangleman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 7th, 2007, 05:48 PM
  5. Kenmore Electronic 90 Series - dead control panel
    By arkadeus in forum Sears Kenmore
    Last Post: July 7th, 2006, 06:42 AM
