Old February 5th, 2006, 05:47 PM
lccow is on a distinguished road
Default Maytag Dishwasher Blinking Lights
We have a Maytag QuietSeries 100 that we bought a year ago. I opened the door when the dry cycle was still on. After I unloaded the dishwasher, the door wouldn't shut and several of the lights were blinking. I read other posts and turned off the power for different lengths of time. That hasn't worked. I do not have the user's manual for some reason--every other manual for the last ten years, but not that one. Can you tell me why it won't latch shut? Thanks.
Old February 6th, 2006, 01:10 AM
It sounds like that latch is stuck in a closed position, get a screwdriver and try to pry that middle piece forward or back-wards slowly, Maytag has had a issue with these latches, you will eventually need a new latch.
Whats the model# of your dishwasher?
Old February 7th, 2006, 06:22 PM
Default Maytag DW Blinking Lights
Thank you for responding!!! The model number is MDB5600AWW. I've tried coaxing the plastic center piece forward and backward and it won't budge. Shall I apply a little more pressure? If it will be going out anyway, I don't have a lot to lose... Thanks again.
Old February 7th, 2006, 11:55 PM
Sure you can give it more pressure.
Here is the latch assembly for your model you can order:
Door latch assembly
Old February 19th, 2006, 11:30 AM
Jake--Thanks so much for your advice. More pressure, and using a small pair of needle-nose pliers to pull the middle piece forward worked to get the door working. If this happens again, I'll be purchasing the latch. Will I be able to replace it myself, or will I have to call in a professional? Thanks again for all your help. This site it great!
Old February 19th, 2006, 02:35 PM
Glad to help lccow!
You could change it yourself, its not that hard.
Maytag Dishwasher Constant Blinking Light Memodos Maytag/Magic Chef/Admiral/Jenn-Air 5 July 10th, 2007 08:33 AM
Maytag Dishwasher MDB6100AWW blinking display lights and won't run? chip718 Maytag/Magic Chef/Admiral/Jenn-Air 1 May 10th, 2007 10:43 AM
Maytag dishwasher for parts beginnersluck Buy, Sell or Trade 0 February 25th, 2007 03:34 PM
Maytag Dishwasher lights blink, won't cycle Jboz Maytag/Magic Chef/Admiral/Jenn-Air 1 December 12th, 2006 01:10 AM
Blinking Lights thehulans Maytag/Magic Chef/Admiral/Jenn-Air 3 February 5th, 2006 11:43 AM
