Results 1 to 10 of 18
Thread: Maytag Performa not draining
    etg408 is offline Member
    Jan 2012
    usa
    Default Maytag Performa not draining
    Model Number: PAV2200AWW
    Brand: Maytag
    Maytag Performa
    Rev 10
    PAV2200AWW
    Guessing on the age as the wife and I just bought the house and the washer dryer came with.
    Ive noticed in the recent past:
    -smell of belt burning
    -water not emptying during spin
    -tried changing cycle to delicate and had success a few times with draining.
    what ive done
    - disconnect belt and hand spin all (3 - motor tub pump) pulleys both ways successfully. (noticed the tub pulley would only spin tub clockwise, assumed had to do with washing cycle)
    - remove pump (3 bolts) and disassemble (4 bolts) and cleaned some lint that didnt seem to hinder movement by hand. reassembled.
    - checked all drain tubes for blockage. none found.
    - all reassembled and tested with extra small cycle. still not draining.
    is this pointing to a faulty timer?
    if not, what should I try next?
    Thank you.
    Oct 2004
    not draining
    What happens instead?
    This unit runs the motor in one direction to agitation and in the other direction to spin and drain.....motor runs but not draining, motor/washer goes dead, drains water slowly....etc? Motor reversing?
    http://www.applianceaid.com/
    NEW Appliance Repair Aid
    http://www.jrappliance.ca
    JRAppliance
    Jan 2012
    usa
    Quote Originally Posted by jeff1 View Post
    First off, thanks for the reply.
    tub spins as fast as it can depending on fullness and have seen water on floor from under washer assumed it was overflow from spinning but not draining.
    I have in the past couple days been able to get it to drain by turning the dial to delicate but that no longer works.
    Oct 2004
    Double check the hoses, double check for something between the tubs like a coin/sock/spong or such. Make sure the impellor inside the pump hasn't broken free and is not really turning when the belt and pulley underneath the washer are turning.
    Maytag Performa not draining-drain-pump-35-6465-00892810.jpg Drain pump assembly Manufacturer Number 35-6465
    JRAppliance
    Jan 2012
    usa
    - both are clear of obstructions.
    - how do I ensure this? is there a way to remove the internal tub/agitator from the water holding tub?
    I assumed it to be free of obstruction as well. my reasoning is the ease with which the water still left in the tub escaped to the floor when I lowered the exit hose from its perch in the drain pipe to the floor in order to check the hoses and remove the pump.
    - i removed the pump and with water still in it, hand spun the pump and water moved as expected.
    Oct 2004
    Yes the wash basket can come off, sometimes peeking through the holes with a flash light can help to find/see something.
    Something like a coin can float around and allow water flow but get sucked into something or over something when the pump engages.....with a not finding a common or simple reason for not draining you may have to start thinking outsise of the box.
    Stick your finger in the pump and try holding it back while you turn the pulley.
    JRAppliance
    Jan 2012
    usa
    ok i have removed the inner tub.
    nothing in it or the hole.
    I disassembled the pump for a second time and its simple mechanics whether it works or not. no broken teeth. pulley controls movement of pump fins.
    nothing blocking either hose.
    what next?
    Oct 2004
    what next?
    Nothing....should drain.
    You said:
    Motor runs in spin and drain mode
    Nothing in the hoses to and from the pump
    Belt should be intact since spinning tries to occur
    Pump is good and not broken
    Nothing is between the tanks
    = should be draining.
    You have missed something along the way.
    Only thing I can think of trying is to prop up the washer, set to spin and drain and observe what is happening underneath....belt, pump, pulleys, etc.
    I once had a bandaid get caught in a drain hose....could blow air through, could run water through at the sink with the hose off the washer but every time I tried the hose on the washer it would not drain
    Attached Thumbnails Attached Thumbnails Maytag Performa not draining-maywashbelts.jpg
    JRAppliance
    Jan 2012
    usa
    i missed focusing on the burning belt smell i mentionedin the first post.
    put it all back together again
    ran no load cycle. all worked ok.
    ran small cycle w clothes wash cycle was fine, spin/drain was slow turning tub and smell of belt. tipped washer back while in cycle saw belt wabbling.
    while tightening the belt, i noticed the motor mount bolts are stripped as i cannot tighten either enough to actually get a grip with those plastic looking thick washers to the metal motor mounting plate.
    new motor or other ideas? i have thought of fashioning a spacer of sorts but i dont like temporary and I dont want to be doing this again anytime soon.
    Oct 2004
    Motor moves to tighten or loosen the belt as needed, spring (#1) keeps tension.
    What part(s) are stripped?
    Attached Thumbnails Attached Thumbnails Maytag Performa not draining-52519.gif
    JRAppliance
  1. Maytag Performa
    By DLC09 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 2nd, 2011, 11:05 AM
  2. Maytag Performa
    By Tagman886 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 26th, 2009, 05:34 PM
  3. Maytag Performa...?
    By walkingonthesun in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 18th, 2007, 10:44 AM
  4. maytag performa
    By babysnake2007 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2007, 06:21 PM
  5. Maytag Performa
    By mummax2 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 28th, 2006, 11:09 AM
