Its likely either the timer or the motor. But check your wiring inside first to make sure none of the wiring is burnt or melted to another wire or ground.
The back console access panel can be removed, unplug your dryer first.
Jake, before I order the timer, I just want to be sure I don't spend the money unnecessarily?
Is there a way to be absolutely sure?
Is there a service manual of this model anywhere online that I can reference as a guide before tinkering around inside?
A new comparable dryer is $299
So, manual on the fly edits of a previos posts are not possible?
Yes, Unplug the dryer and remove all the wires to the timer, make down on paper where the wires go first, then you'd need a ohm meter to ohm each timer terminal to ground on the cabinet. If you get continuity on any of them to ground, then its a bad timer.
When I connect one lead of the ohmeter to a terminal on the timer (with all wires disconnected) and the other to ground on the metal cabinet itself, Which signifies the timer is BAD, Zero or infinity? and what setting should the ohmeter be on?
I'm no expert with electric.
I guess if the timer is good then it's the motor and I guess it pays to simply get a new dryer.
Watch this video, it shows how to ohm for continuity. In your case one meter probe on the timer terminal, one meter probe to ground. So if the meter doesn't move or change numbers, that means no continuity.
