Results 1 to 3 of 3
Thread: Fix one problem, now a new one stumps me
    pookiebear43 is offline Member
    Feb 2012
    NW Arkansas
    Default Fix one problem, now a new one stumps me
    Model Number: mav5758eww
    Brand: Maytag
    I’ve done some research but nobody has mentioned anythingjust like my problem
    HERE IS WHAT HAPPENED
    Was using the washer and heard a clunk sound, washer stoppedworking. Finally found that the
    e-clip/c-clip had broken and the main shaft and the large pulleyhad fallen off. I called a local parts place
    for replacement, he sent me to Lowes said same thing butcheaper. I bought new clip and installed it easy enough, but…
    HERE IS MY PROBLEM NOW
    Now my washer spins slowly and the agitator works during thespin cycle.
    I’ve checked the belt, its ok motor pivots easily too. Checkedthe brake housing during operation and it dose not get even warm. I placed thelittle plastic clog thing on the end of the shaft and turned both directionswith no resistance. Read elsewhere this means bad trans. What do you all think.Something else I could try??
    Yes, Your transmission has gone out.
    Here's the transmission for your model you can order here:
    Manufacturer part number 35-6615 is RepairClinic item number 1472816
    35-6615
    If you change the transmission yourself, its a big job, be prepared for an all day job.
    Feb 2012
    NW Arkansas
    Thanks!!!
    Wanted second opinion to be sure.
  1. is it a timer problem or door switch problem?
    By medman57 in forum Sears Kenmore
    Last Post: December 6th, 2011, 12:57 PM
  2. Cooling problem, maybe freezer problem too
    By Odysseus in forum GE/Hotpoint
    Last Post: March 1st, 2011, 09:48 PM
  3. Fixed cooling problem, but created ice problem.
    By rayvera in forum KitchenAid
    Last Post: August 16th, 2009, 05:21 PM
