Results 1 to 6 of 6
Thread: Maytag Neptune Front Loader not draining
    May 2012
    Louisvile, KY
    Default Maytag Neptune Front Loader not draining
    Model Number: MAH6700AWW
    Brand: Maytag
    Washer stopped. Won't drain, just buzzes. Gave ND error code. Users manual no help.
    ND=No Drain.
    You'll need to unplug your washer and pull it out from the wall, then remove the back access panel and remove the rubber hoses to it, becareful water may come gushing out, see if you can get a pan or pot to catch the water in.
    Then remove the drain pump and check for something inside clogging it.
    Manufacturer's Number: 34001320
    34001320
    May 2012
    Louisvile, KY
    Thank you Jake for the direction. I pulled off the motor and found a penny that was preventing the fan from spinning. Your very much appreciated.
    Excellent, good find.
    jimijean is offline Member
    Dec 2012
    Austin, TX
    I am having an "ND" code issue with my Maytag Neptune MAH6700AWW, as well.
    I have done everything as described above. I also found a penny. Made sure that the drain hose is clear and then put everything back together. The first test load, consisting of the towels that I used to clean up my mess from my initial investigation, I got the same error. I can hear the pump running, but still getting the error.
    Once again, took the hoses off and removed the pump.
    Removed the pump from the housing. Nothing apparently wrong with the impeller. There is about 1/8" of play between the impeller and the pump housing, which a call to a local appliance shop verified is normal. Hooked it up to the leads inside the washer and tested it with 'spin only' selected. The pump appears to be running normally.
    Removed the black boot on the bottom of the washer, which attaches to the "IN" side of the pump. No obstruction found.
    So, any ideas? There are no apparent obstructions and the pump appears to be functioning normally. Still getting the "ND" error code.
    Here's the service manual for your model:
    http://www.applianceblog.com/manuals/16026186.pdf
    Read page 17 where it says clear diagnostic code. And see if it clears and runs normal, if not then since your pump is fine, that just leaves the control board as bad.
    They make 3 different control boards for this model, whats the serial# of your washer?
    Once you post the serial# I can link you to the one for your model.
    Here's the control board for your model if your serial# starts with 10:
    Manufacturer's Number: 34001488
    If you purchase parts from our links here and you install them and it doesn't fix the problem, you have a 365 day full refund when you ship them back.
  1. Maytag Neptune Front loader
    By dguinaugh in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 15th, 2012, 03:21 PM
  2. Maytag Neptune front loader washer spin cycle sound like helicopter?!?
    By Stevenanthonyh in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: December 24th, 2011, 12:06 PM
  3. Maytag Neptune Overflowing onto floor...(!) Maytag Neptune front load
    By mjs98116 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 29th, 2011, 12:10 AM
  4. Maytag Neptune Front Loader Error Code 3E
    By Terry Lueders in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 29th, 2010, 12:05 PM
