Old April 8th, 2005, 03:19 PM
althis is on a distinguished road
Post imported post
I have a Maytag refrigerator model MTB2156BEW. It does not cool either freezer or food compartment. The fan is working but it blows only warm air. I'm an old tv serviceman so I can make voltage and resistance checks if I knew where to look. Thanks in advance for any help. Al
Old April 8th, 2005, 03:43 PM
Post imported post
**It does not cool either freezer or food compartment. The fan is working but it blows only warm air.**
Is the compressor running? Is the condnesor fan motor ( beside the compressor ) running? Any frost on the freezer back wall?
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Old April 8th, 2005, 05:26 PM
Post imported post
Hi Jeff
No the compressor is not running
Yes the condenser fan motor is running
Al
Old April 8th, 2005, 08:12 PM
Post imported post
Evaporator fan motor running, condensor fan motor running should = cold control and defrost timer are sending power ok....problem in the compressor or the overload/start relay.
Have seen a couple of "open" ( no continuity ) overloads. The relay, overload and compressor can be ohmed for continuity.
Some stuff that may help...
http://www.applianceaid.com/refrigerator.html#clicking
Wire diagram if needed
JRAppliance
Old April 11th, 2005, 07:08 AM
Post imported post
Hi Jeff
How do you guys do it,working on these things every day.laying on the floor, working in a cramped area, I'm starting to appreciate appliance repairmen more now.Anyhow I took off a cover that is on the compressor and found what looks like relay switches, after removing the connectors I measured ohms across 3 terminals and found very low ohms,about 4 ohms, seems low for a compressor. By now I figured let somebody that knows what they are doing look at it,so I put everything back together and closed it up. Just to check I plugged it in and turned it on. There was an arcing noise momentarily and the unit started working normally,even made icecubes. After it was cold enough it shut off,then when it came back on again-you guessed it- just warm air again.Does this sound like bad or intermittent relays or bad winding in the compressor? I won't bother you with this problem again- It might be time to call my sears service co. Thanks for your time
Al
Old April 11th, 2005, 11:20 AM
Dan O.'s Avatar
Post imported post
althis wrote:
After it was cold enough it shut off, then when it came back on again -you guessed it- just warm air again.
Which "came back on again"? The fans, the compressor??
If the compressor did not come back on again when the fans, etc. did, it could just be a problem in the compressor's relay or overload protector or in the compressor itself.
If in the compressor, the part itself should be covered by a warranty for 5-years from date of purchase although the labour to replace it ($$$+) would not usually be (see the following link).
LINK > Appliance411 : Limited Warranties
JFYI
Dan O.
Appliance411.com
=D~~~~~~
Old April 12th, 2005, 05:15 AM
Post imported post
**After it was cold enough it shut off,then when it came back on again-you guessed it- just warm air again**
Possible both
Compressor will likely be amp meter tested to make sure it is not drawing too much current which in turn can/could damage the relay and overload.
JRAppliance
Old April 18th, 2005, 01:58 PM
mills is on a distinguished road
Post imported post
Our 18 mo Maytag MTB2156GES just blew on Sunday. A repairperson diagnosed the problem this afternoon as bad relay on compressor. Googled and hit on this thread.
Is this a common problem for this refrigerator? It's going to put us back $175 in labor and parts (not to mention what $$ wasted on spoilt food); should we order a couple of spare so we can repair it ourselves in the future?? Does this put undue strain on compressor?
Repair person did some hand waving about not vaccuming coils and not enough clearance around the unit. However, manual specifically states *not* to clean the coils and the space around unit meets specs in manual. Any suggestions to prevent future failures?
Much obliged for your advice!
Old April 18th, 2005, 02:17 PM
Post imported post
Its kinda rare to see a relay on the compressor to go out on these maytags.
The compressor is not running at all?
All the fans working?
Frost build up on the freezer back panel?
The most i see go wrong with these are the defrost board.
As far as cleaning the condenser, you are right, all maytags have a self-cleaning condenser from 1999-present. I myself own a 1999 freezer on top maytag refrigerator, and i have never cleaned the condenser since it was brand new in 1999.
Old April 18th, 2005, 03:20 PM
Post imported post
Thanks for speedy reply!
  • Fans are working.
  • Can hear compressor come on, but then clicks off again. Tested it w voltmeter and seems fine.
  • Affirmative frost on panel (according to repairperson). Water dripping all night,running down refrig door gasket and pooling on floor.
Repairperson commented that compressor was 'hot' so I'm worried that there's something wrong wunit or installcausing relay to fail. Any thoughts? Just a bad part?
[FIXED] Maytag Refrigerator Model MSD2756DEB is not cooling properly suk Maytag/Magic Chef/Admiral/Jenn-Air 249 June 8th, 2009 12:57 AM
i have a maytag model MZD2766GEB fridge not cooling nubsy Maytag/Magic Chef/Admiral/Jenn-Air 7 April 28th, 2007 11:30 AM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag Model MSD2732GRQ clicking noise/not cooling properly nova817 Maytag/Magic Chef/Admiral/Jenn-Air 1 November 26th, 2005 06:01 AM
Maytag Refrigerator - Model PTB2154GRW - not cooling kpd Maytag/Magic Chef/Admiral/Jenn-Air 6 April 6th, 2005 12:12 AM
