June 8th, 2012, 08:42 PM
Maytag Neptune Dryer Diagnosis Problem
Hello,
My mother had her Neptune Dryer diagnosed by a repair man. He told her the "main elec control board assembly" was bad. They wanted $300 for the board.
Replaced the board today, same issue.
The Number board Estimated Time shows 50
Dr Temp = regular
Cycle = Normal
Signal = 0n
Start/Pause was blinking.
None of the buttons are responding.
Did the repair rep get it wrong? Or, is the board I purchased also toast?
How can I diagnose this further?
Thanks in advance for your help.
Regards,
redbug2
June 9th, 2012, 10:56 AM
Yes, the repair person got it wrong.
You need the control panel touchpad assembly.
Here's the membrane control panel touchpad assembly for your model you can order(For Maytag serial# that starts with 68 or lower):
Manufacturer's Number: 33002536
Here's the membrane control panel touchpad assembly for your model if your dryer serial# starts with 69 or higher:
Manufacturer's Number: 22004444
July 6th, 2012, 03:23 AM
OK, finally got around to replacing the control panel touch assembly... I put in the newer control panel while I was at it. While I was there it did start up.
Now my mother is telling me the dryer will start, run for a little while and then stop. The sounds she described on the phone sounded like a motor stopping under a load? I'm going over there soon and will get more information...
Do you think this new stopping problem was the actual cause of the membrane failure? Or, has my mother put the dryer into some sort of mode that actually stops it normally? She says she's never heard the dryer do that before.
I think I'll also try putting in the original control panel while I'm there.
July 6th, 2012, 10:22 AM
You'll have to go there and see whats going on and run a load in all cycles and see how long it runs before it stops, then if and when it stops try and restart it again right away.
By HVACR service tech in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 29th, 2012, 05:39 PM
By NN4S in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 25th, 2012, 08:57 AM
By allbrand in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 6th, 2011, 10:16 AM
By narleycharlie in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 6th, 2009, 11:23 AM
By rickbbb in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 28th, 2007, 01:26 PM
