Old March 1st, 2006, 04:55 PM
bhowe is on a distinguished road
Default Maytag MTB Series Not Cooling
I just wanted to post here to let you all know how appreciative I am for your site. I looked over the site for the past hour or so and kept running to my refrigerator that came with my newly purchased house. I'd like to describe my problem in case anybody else has the same dilemma.
First my freezer on the Maytag MTB2456DEG was not cooling off. The refrigerator seemed to work fine. I kept shuffling the cool switch around and the freezer would turn on and cool off. Ultimately, this stopped working and neither the freezer or the refrigerator would remain cold. Power worked, and there wasn't any weird noises.
After reading your site I decided to check the defrost timer. It was at this time that I realized the lower section of the freezer was warm. The timer was stuck in the on position. Warm air was blowing across the underside of the freezer the whole time which is why the freezer went first.
BTW, with this model the defrost timer is in the refrigerator, on the "ceiling" of the inner box. There is a plastic knob in there which you can turn with a screwdriver without even taking the panel off and if the timer is going bad then turning it will fix the problem (atleast until you get your new timer). I learned all this on the site too, gotta give credit where it's due.
Without your site I probably would have spent a lot of time researching the problem without much of an idea what was going on. Thanks for all the help.
-Brad
Old March 1st, 2006, 10:05 PM
Thanks Brad for your nice compliments.
Old March 18th, 2006, 01:19 PM
Ok, so I was a little to excited at what seemed like an easy fix. I bought the new defrost timer and put it in, but it only worked for a day. Now, the fan in the freezer runs continuously but nothing is cooled. I was away for a couple days and had my girlfriend switch the beer cooler in the basement over to the primary refrigerator until we can get this fixed. I'll have to search your site some more to figure out the problem.
Old March 18th, 2006, 05:05 PM
Is it completely warm in the freezer now?
No Frost build up on the inside back of the freezer panel?
Compressor in the back is running?
Old March 20th, 2006, 10:51 AM
Evaporator Fan Runs, Compressor Fan Runs (fan in the middle of the coil in the back), Freezer is warm and Refrigerator is warm, Compressor does not turn on. I'm thinking it's one of the relays on the compressor. Can you tell me if I can test these relays without the compressor working? Would I need a Hall Effect Clip on Ampmeter to do this? I see one black box that is attached to the side of the refrigerator by the compressor (guessing this is the startup relay) and two plastic electrical devices on the compressor itself (overload and something else maybe?).
Guy at the local appliance store tells me I probably need a new compressor, but he hasn't looked at it. I haven't read too much on this site about compressors going bad.
Old March 20th, 2006, 01:33 PM
You would need an ohm meter to ohm out the relay for continuity, yes that black box is attached to the compressor terminal pins, it just pulls off, then you ohm it out with the refrigerator unplugged.
You can also do a voltage check on that as well, it should read 120 volts.
If that relay checks good, then your compressor is bad, and all compressors have a 5 yr. warranty on them, PARTS & LABOR.
Old March 21st, 2006, 05:45 PM
Ok, let's start over here. I went to the local appliance parts store for some more help. Black box is the run capacitor, black 4 pronged relay on the compressor itself with 2 wires attached is the overload relay...I think, white one prong with one wire attached underneath that black 4 pronged device is????
So, black 4 pronged device has no problem...but I own a new one. White one pronged had infinite resistance/no continuity and I thought it should have so I broke it open. Not sure if there is a problem with this or not....but here is the cool part. I think the wire attached to the front supplies current, heats up a coil which then pops a concave circular foil upward due to the heat and this releases a contact which should also disconnect the current. I could be totally off here, but that what it looks like to me. And by the way, tomorrow I'm going to own a new one.
I thought the problem was the defrost timer because I turned the dial on it and the refrigerator started working...but not anymore. My girlfriend thinks the refrigerator starts working when she shuffles the freezer temp selector around...but not anymore. We both think the kitchen stinks from the stinky mushrooms that we didn't clean out soon enough.
Evaporator Fan Runs, Condensor Fan Runs, Run Capacitor is good, Black 4 prong relay is good, new defrost timer is good, Condensor will not run and I'm reading about the thermostat's to figure out if they are a problem. Any help is welcome.
Old March 21st, 2006, 10:24 PM
The Overload device.
Ok, if that white overload device piece didn't have continuity, its definitely bad.
A new one should fix it up for you.
Old March 22nd, 2006, 09:18 PM
Jake, you're the man. I bought the overload relay today and it works. My frig has been running for about an hour now and it's colder then it's been in the past five days. I think the guy at the appliance store had me buy the PTL Relay just because he wanted to sell me something. I went in and asked for the overload relay...but came out with that. Oh well, I got atleast $20 worth of info out of him.
Now that it's running, what do you think makes the overload die? I don't want to keep buying overload relays if there is an underlying cause here.
Anyhow, thank you so much....I'm very appreciative for your help.
Brad
Old March 23rd, 2006, 12:43 AM
That relay is very rare to go out, keeping the condenser coil clean will help make it last longer, as most of them just go out because of excessive heat build up from the condenser and compressor. That condenser fan cools the condenser and compressor, so if the condenser coil is clean, the air flow will be good to cool properly.
Glad you got it fixed Brad!
Maytag Legacy series dryer walks Jann K Maytag/Magic Chef/Admiral/Jenn-Air 6 December 3rd, 2007 08:41 PM
Maytag ptb1954grw no freezer/no fridge cooling Gugerluards Maytag/Magic Chef/Admiral/Jenn-Air 3 December 29th, 2006 05:54 AM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag MSD2456GE Quit Cooling then... Alf50990 Maytag/Magic Chef/Admiral/Jenn-Air 11 March 27th, 2006 12:39 AM
